09-14-2012 08:36 PM
291 ... 89101112
tools
  1. jondevere's Avatar
    Or u can use OSCC
    Sent from my PC36100 using Tapatalk
    06-29-2011 10:35 AM
  2. Seahawks4Life86's Avatar
    did you revert to stock using XIONIA?
    Am I actually able to return to Stock using the Xionia? Is that even possible, oh well... Im not going back to stock now, I have Reborn ROM v2.2.2.
    06-29-2011 12:58 PM
  3. jondevere's Avatar
    No not possible because xionia is JUST A CUSTOM RECOVERY. Xionia is NOT stock and not a program to return to stock. You can use OSCC to return to stock recovery, im sure there are other ways as well
    twtippets likes this.
    06-29-2011 09:48 PM
  4. Android4YourPhone's Avatar
    Does anyone have alternative download links for ...
    GNM's v1.1.0 Recovery Kernel.
    flash_image.
    Stock V8 Nandroid Dump
    the V8 to V9 update
    ...files?
    07-01-2011 01:13 PM
  5. marcus a rowe's Avatar
    thanks this is exactly what i need.
    07-04-2011 12:22 AM
  6. Seahawks4Life86's Avatar
    Can I get the links to use OSCC or KP500? I don't even know where to start looking. :P
    07-05-2011 07:17 AM
  7. berry_lthird's Avatar
    HOLY LORD JESUS....IT WORKED! :-O
    With a few steps taken from this thread:
    http://forum.androidcentral.com/lg-o...optimus-s.html
    Had to make sure that superuser was installed. That was the hitch.
    THANK YOU VERY, VERY MUCH!!!
    07-05-2011 06:12 PM
  8. Seahawks4Life86's Avatar
    Hello everyone, after a week worth of work. I was finally able to get the Stock Sprint ROM back up and running. I did root it but now I want to get the Stock Recovery back on my phone. I have LS670ZVD on my phone at the moment but I don't want to go back down to V9 again and have to call Sprint up. I just got it fixed, is there anyway to get the Stock Recovery back, I tried using the V9 Stock Recovery but it just comes up to a black screen. But when I hit the Menu button 2 times, it reboots my phone into the Sprint ROM and works as proceeded. Any help would be appreciated!
    Please help me! Thank you guys.
    What I have tried, KP500 (Diag), OSCC tool, Reverting to V9 using KP500 method then force flashing to VC and then using the LG Updater tool to get ZVD.
    EDIT: Instead of looking for a way to install the Stock Recovery, I installed the Xionia Clockwork Recovery and installed the Xionia OC Kernel. I still currently use the Sprint Stock ROM.
    07-05-2011 08:54 PM
  9. evilmonkey335's Avatar
    its telling me the links are brokeing please fix
    07-05-2011 09:49 PM
  10. Beatzbyreefah's Avatar
    HEY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    THE:
    the V8 to V9 update
    flash_image
    LINKS DONT WORK! CAN US NOOBS GET THE UPDATED LIKNS????
    07-06-2011 02:24 AM
  11. dieselboy7's Avatar
    Thanks a bunch this saved my butt!
    07-06-2011 12:21 PM
  12. vfr_geek's Avatar
    having major problems trying to navigate a blank screen. can anyone give a screen shot of the different phases so i know where they are at during the unroot process for v8? or is there an easier way to get this all working?
    Please help I need to take my phone in tomorrow to have my phone checked out, cuz i'm not getting any of my incoming calls and some are very very important. could mean life or death really lol...
    any help is appreciated.
    07-18-2011 11:36 PM
  13. ichihollow's Avatar
    androidscreencast - Desktop app to control an android device remotely - Google Project Hosting
    if you're at v8, you're already unrooted, or should be depending on your method. I would tell you since you're already at v8, follow the steps to finish in adb, but either way you're going to have to connect to a computer, and don't get caught with anything less then VC/VD on your phone, it's one of the newer ones with a different display. if you have an v7-v9 on your phone and a smart tech sees it, he'll call your warranty void, and you really don't want that.
    07-19-2011 01:51 AM
  14. vfr_geek's Avatar
    thank you yeah i was getting onto that android screencast but ran out of time earlier gonna try getting it right now so even if i have insurance on the phone they won't do work on it?
    07-19-2011 03:29 AM
  15. ichihollow's Avatar
    If you have a blank screen when your running v7-v9 that means you have a newer optimus S. For some reason with out changing anything else on the phone LG changed the display, with that new display comes new "divers" which vc and vd have. That being said it means the new phones never had v7-v9 and if a newer one had v7-v9 it means the warranty was voided. Most people looking at phones to replace them aren't very knowledgeable about the specifics of each phone, thus most wont know anything anyway but a smart tech may figure it out and if he's/she's having a bad day, they might blow the whistle. But you were prepared for that going in to the rooting world in the first place, dont have to remind you of that. Besides once you get the phone all squared away no one will be able to tell the difference anyways. Speaking of which somethings been nothing me. If you're at v8 right now forget screen cast why not just use LG update tool to just get you back to the STD release?
    07-19-2011 03:41 AM
  16. 64fairlane's Avatar
    The links to the GNM's v1.1.0 Recovery Kernel and the flash_image do not work. Is there anyone that has these files that could get them to me somehow by chance?
    I am trying to get this phone back to stock as I will be selling one of my Optimus S and the guy doesn't want it rooted.
    Thanks.
    07-20-2011 12:33 AM
  17. ichihollow's Avatar
    Thanks.
    Use kdz or kp 500 or LG update tool
    07-20-2011 12:38 AM
  18. wingedscorpion21's Avatar
    Thanks.
    im having the same problem
    07-20-2011 11:30 PM
  19. blackwaterstout's Avatar
    Since unrooting my phone and returnign to stock I'm having a problem with my PC recognizing my phone in windows. I tried connecting with USB debuggin enabled and also tried with it disabled. All it wants to do is charge the battery. Any ideas how I can fix this?
    07-23-2011 09:18 PM
  20. jondevere's Avatar
    I would advise to check the USB cable or the port that it connects into on your computer. Returning to stock doesnt affect the USB driver.
    07-23-2011 09:47 PM
  21. blackwaterstout's Avatar
    Cable and port are fine. I use it with my wifes phone with no problems. Not sure what to do now. I need connectivity in order to use easy tether and right now I'm stuck with no access.
    Any other ideas?
    07-23-2011 09:54 PM
  22. TriWolf's Avatar
    Hey the links are broken can you fix please
    07-25-2011 11:17 PM
  23. ichihollow's Avatar
    your best bet is a force flash with kp500 or kdz
    TriWolf likes this.
    07-26-2011 11:11 PM
  24. TriWolf's Avatar
    Thanks ill search around for them but can you tell me if this resets the phone to factory stock or just sets the original recovery only.
    07-27-2011 04:17 AM
  25. ichihollow's Avatar
    It results in a factory issued phone just keep in mind the "newer" optimus s phones have different LCD panels so the earliest they can go back is vc.
    TriWolf likes this.
    07-27-2011 04:21 AM
291 ... 89101112
