fristuff
Active member
So would this go back to the state where we bought the phone? Like, even if we get updates, we'll be able to accept it, and even if we wipe data through privacy, it won't be bricked?
Now you should be in GNM's recovery with aqua-colored text. The controls are: Up = VolUP, Down = VolDown, Back = Back, Select = Menu (right of home).
13) Go down to "USB-MS Toggle"
14) Select "USB-MS Toggle SDCard"
15) Download my Stock V8 Nandroid Dump
16) Unzip it into the root of the USB Device/SDCard
17) Safely remove the USB device using your PC OS.
18) Press menu to disable USB-MS Toggle.
19) Press back.
20) Select "Backup/Restore".
21) Select "Nand restore".
22) Select "mem=477M".
23) Select "BCDMRS12-20101122-1915"
24) Press menu to confirm.
25) When the process is complete, DO NOT REBOOT. Nandroid does NOT flash recovery by default, to protect from losing your custom recovery. In this case we WANT to lose it, otherwise we won't be stock, and OTA updates will not work. Therefore we must...
26) adb shell
27) mount /sdcard (if this throws an error about "device or resource busy", just ignore it)
28) cd /sdcard/nandroid/mem=477M/BCDMRS12-20101122-1915
29) flash_image recovery recovery.img
30) reboot
Now you are back to V8 stock! Enjoy!
To upgrade to V9:
Due to the kernel being from V9, the phone thinks the firmware is up to date, so you will NOT be prompted for the OTA update. However, since I have a copy of it, you can manually install it. Heres how:
1) Plug phone into PC
2) Enable USB Mass Storage
3) Download the V8 to V9 update and place it in the root of the USB Device/SDCard as "update.zip" (renaming it is important!)
4) run the following from cmd prompt: "adb reboot recovery"
5) You are now at LG's dark-blue recovery screen (should only be 4 options, if not STOP HERE)
6) Select the option with "update.zip"
7) follow instructions on screen (VERY IMPORTANT)
You now have V9 Radio/Baseband and V9 stock update. You can delete the update.zip from your SDCard when you are back into Android.
i followed all instructions and now im back to stock... but when i try to install the update.zip it says "
-- Install from sdcard...
Finding update package...
Opening update package...
Verifying update package...
E:Failed to open /sdcard/update.zip (no such file or directory)
E:signature Verification failed
Installation aborted.
but i named it update.zip and placed it on the root of my sdcard... can someone help me?
I am on stock rom and installed custom recovery. I need to get rid of custom recovery (I did tried nand restore from custom recovery but custom recovery is still there) . can some one give the instructions or do I need to follow from 1st post? thanks in advance
That's where I got with mine when I gave up and decided to flash my original backup instead of the one in this thread. Shoot me a pm and i can give you a copy of my clean backup that is working for me. It is the v9
I have made a nandroid dump of the complete V8 stock system, including kernel, rom, recovery.. everything except the evil devil RADIO. Restoring to V8 will allow you to accept the Sprint V9 update and update your radio PROPERLY.
It will also allow you to bring your phone in for repair, or just remove any hacks you did so you can sell the phone, ect.
This is 99.9% STOCK. This returns your phone to the state it was when you opened the box.
