Attempting to install custom recovery on Optimus S
I have rooted my Optimus S as per the "Idiots Guide to rooting" and am having some trouble with the last part.
I am attemptimg to install the custom recovery and i am having trouble with this part
1) You need two files, flash_image.zip and recovery-RA-GNM-thunderc-s-1.1.0.img.zip, both of which can be found towards the bottom of the original thread. Copy them to the root of your SD card.
2)Plug in the phone like we did in Section 1, and open up the ADB shell (like we did before- enter the cmd, navigate to where your SDK is installed, and type adb shell).
Check your display to see if Superuser is asking you to grant permission to have root access to the commands coming in. Make sure you click to allow it if it asks. You should be greeted with a # prompt (If not, the prompt is not being granted root access and something is wrong).
3)Enter the following commands:
mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system
cat /sdcard/flash_image > /system/bin/flash_image
chmod 755 /system/bin/flash_image
mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak
mount -o remount,ro -t yaffs2 /dev/block/mtdblock5 /system
flash_image recovery /sdcard/recovery-RA-GNM-thunderc-s-1.1.0.img
reboot recovery
When I put the two files on the sd card and begin the commands in adb shell I am getting a "file not found" or "invalid length" error.
Does anyone have a clue what is wrong here? Any help would be greatly appreciated.
