Zefie cordell
I had the same error until I had LG Support tool running in the background.
Yeah, it does sound like most of the file extraction problem on this thread are related to the cab file it points you to download. I think it is the source rather than the downloaders that are the problem, as multiple people saw the problem.
I like KP500 better anyway, less to install and no dependency on MSXML.
Nah, we figured out the problem.
The cab file referenced in the first post ends up downloading a file that caused the LG Software Updater to come back with a file extract error.
We discovered this when shifting our efforts to using the KP500 tool, which is basically a command line version of KDZ.
One user had downloaded a V9 cab that zefie had archived. Another had the V9 cab from the first post here. The latter had the file extract error from the LG Software Updater tool. The former did not. We compared checksums and found the cab files were different.
I suspect if we had gone back and tried the working V9 cab with KDZ then everything would have worked fine, but we didn't know that at the time we were trying KDZ and everyone was stuck and the file extract error.
Thanks for getting back to us.
Don't know, possibly there is some problem with the current download from LG that wasn't present when you downloaded it. Possibly it depends how the file gets downloaded. You could run a checksum comparing the one that worked for you with the current one. A couple of people on this thread all ran into the same extract file error.Why would this be though? Since the cab from this post has worked successfully before (my output shows proof of this)?
I'm trying this procedure on a Optimus V using the associated Optimus V firmware from csmg.lgmobile.com. However, I am getting the same kdz extraction error. I don't suppose anyone knows where to download a working cab file for the Optimus V? I assume I can't flash the Optimus S firmware onto it. Am I mistaken?
No, you can't use the Optimus S firmware. If you're getting that error with the correct cab file then the md5 checksum is incorrect which means the LG site is having transmission issues. So, you'll need to download from another source. Can I see the specific link you downloaded from, just to be sure you've got the correct one?
These may be of some help...
http://csmg.lgmobile.com:9002/csmg/b2c/client/ezlooks_model_list.jsp?model=VM670
http://csmg.lgmobile.com:9002/csmg/b2c/client/auth_model_check2.jsp?esn="MEID here"
You can also try using KP500 Utils (a command-line based version of KDZ): MEGAUPLOAD - The leading online storage and file delivery service
And the log ends with this:Updating is not possible any longer due to a fatal error while the LG Mobile Phone Software Update.
23:49:21 : ****************CheckAndDownload********************
23:49:21 : ******Extract Start VM670ZV4_13.S4_13.P61007.cab*****
23:49:21 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
23:49:21 : ExtractInfo Error(0)
23:49:21 : Extract cab file error.
23:49:21 : [C:\ProgramData\LGMOBILEAX\Phone] オコナ荳ョ サ霖ヲ ステオオ
23:49:21 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
23:49:21 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
23:49:21 : CLGMobileHttp Class シメク・テタロ.
23:49:21 : CLGMobileHttp Class シメク・..
23:49:21 : Page_Error コホコミタヤエマエル
23:49:21 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
00:04:22 : ****************CheckAndDownload********************
00:04:22 : ******Extract Start VM670ZV4_13.S4_13.P61007.cab*****
00:04:22 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
00:04:22 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\VM670ZV4_13.S4_13.P61007.wdb\n
00:04:22 : WDB(or DZ) FullPath(C:\ProgramData\LGMOBILEAX\Phone\\VM670ZV4_13.S4_13.P61007.wdb)
00:04:22 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\VM670ZV4_13.S4_13.P61007.wdh\n
00:04:22 : Necessary information not found\n\nPlease contact via http://www.lgservice.com[009,400,102,102,102].
00:04:22 : [C:\ProgramData\LGMOBILEAX\Phone] オコナ荳ョ サ霖ヲ ステオオ
00:04:23 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
00:04:23 : CLGMobileHttp Class シメク・テタロ.
00:04:23 : CLGMobileHttp Class シメク・..
00:04:23 : Page_Error コホコミタヤエマエル
00:04:23 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
Thank you for the suggestions; I appreciate it!
