Okay guys, I used this method for my bricked Optimus V. I was unable to get passed the LG boot up screen and was unable to use any key presses to get into system recovery or anything like that. So I tried this and it worked perfectly. BUT, now my Virgin Mobile Optimus is now SPRINT. I'm glad I was able to unbrick it, but now how do I change it back to Virgin Mobile? I've tried using most cab files out there but they don't seem to be working. Can someone please help me. Th cab's I used are VM670ZV4_13.S4_13.P61007.cab(this is missing a dll file) and VM670ZV5_07.cab. The sprint one I used came from Zefie..
Index of /zefie/files/cell/LGLS670/roms/LGUpdater/cab - Persona Files
LS670ZVD_12.SD_12.P60675.cab
What can I do? Please help me
These are the steps I took..
1) Disconnect phone from PC, power, and battery
2) Get kp500 utils v0.4.2 (MEGAUPLOAD - The leading online storage and file delivery service)
3) Get cab
http://files.persona.cc/zefie/files/cell/LGLS670/roms/LGUpdater/cab/]Index of /zefie/files/cell/LGLS670/roms/LGUpdater/cab - Persona Files
4) Save cab as C:\LS670ZVC_11.SC_11.P60674.cab
5) Run KP500-Utils-EN.exe, need only that exe and all the DLLs from
zip in step 2
6) Press J
7) Model: LS670
8) Cab: C:\LS670ZVC_11.SC_11.P60674.cab (u can paste this into cmd
prompt by clicking icon on the top left, edit, paste)
9) Version: LS670ZVC
10) When LG fails to find your phone, launch "emergency mode". When
E-mode is active and the drivers are installed, press the "restart"
button on the LG update
11) The LG update will fail and say it lost connection with your
phone. The phone will say do not remove power. But guess what.. you
have to. So do so. Then plug it back in without any button voodoo and
it should go back to the updating warning.( if there is a % on the screen do not pull the cable)
12) Press restart on LG Updater and enjoy.
This is the Log File from trying to use the above VM cab files..
05:11:09 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
05:11:09 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
05:11:09 : Start Date : 2012-03-26 05:11:09
05:11:09 : -------- Buyer Test mode ---------
05:11:09 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
05:11:09 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
05:11:09 : *****CheckOS Start********
05:11:09 : Microsoft_Windows_Vista Professional_
05:11:09 : *****CheckPCSyncPrograms Start*****
05:11:10 : PCSyncPrograms Not Found
05:11:10 : SetEmerModeAT()
05:11:10 : _IsConnectedPhone Call
05:11:15 : _IsConnectedPhone(1)
05:11:15 : 0 - NotConnected.
05:11:15 : 1 - Normal connect success
05:11:15 : 2 - Emergency connect success
05:11:19 : Checking the connection with the cell phone...
05:11:19 : dwWaitResetTime(40000 ms)
05:11:20 : Phone Mode(1)
05:11:20 : *****GetPhoneType Start*****
05:11:23 : Phone Type : CDMA
05:11:23 : *****Start GetPreviousStep*****
05:11:23 : _GetPreviousStep(dwStep:0xffff)
05:11:23 : _SetPhoneNumber retval=1
05:11:23 : *****GetPhoneModel Start*****
05:11:25 : *****GetPhoneBinaryVersion Start*****
05:11:25 : Phone Bin Version : LS670ZVD_12
05:11:25 : *****Get ESN / IMEI / MEID Start*****
05:11:36 : ESN/IMEI/MEID : 80F5C8B2
05:11:36 : *****GetPhoneNumber Start*****
05:11:39 : Phone Number : 80F5C8B2
05:11:39 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : 80F5C8B2, Model :
05:11:39 : *******CheckBinVersion***************
05:11:39 : New Bin Version(VM670ZV4_13), Current Ver(LS670ZVD_12)
05:11:42 : _GetAuthMark : wAuthMark(23596)
05:11:42 : Wait 3Sec
05:11:47 : _SetAuthMark Ok : wAuthMark(23596), PhoneMode(1)
05:11:47 : *****Start _GetBatteryLevel*****
05:11:50 : Battery(5)
05:11:51 : ResetPhone...
05:11:51 : Checking the connection with the cell phone...
05:11:51 : dwWaitResetTime(40000 ms)
05:12:21 : _IsConnectedPhone Call
05:12:27 : _IsConnectedPhone(1)
05:12:27 : 0 - NotConnected.
05:12:27 : 1 - Normal connect success
05:12:27 : 2 - Emergency connect success
05:12:27 : Phone Mode(1)
05:12:27 : m_dwBootWaitTime(35558)
05:12:27 : Checking the connection with the cell phone...
05:12:27 : dwWaitResetTime(30000 ms)
05:12:57 : _IsConnectedPhone Call
05:13:02 : _IsConnectedPhone(1)
05:13:02 : 0 - NotConnected.
05:13:02 : 1 - Normal connect success
05:13:02 : 2 - Emergency connect success
05:13:02 : Phone Mode(1)
05:13:02 : Call _ModeOffline()
05:13:03 : *****CheckPCSyncPrograms Start*****
05:13:04 : PCSyncPrograms Not Found
05:13:05 : CLGMobileHttp Class ?Ҹ????.
05:13:05 : CLGMobileHttp Class ?Ҹ?...
05:13:05 : ****************CheckAndDownload********************
05:13:05 : ******Extract Start C:\VM670ZV4_13.S4_13.P61007.CAB*****
05:13:05 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
05:13:05 : ExtractInfo Error(0)
05:13:05 : Extract cab file error.
05:13:05 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
05:13:05 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
05:13:05 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
05:13:05 : Page_Error ?κ??Դϴ?
05:13:05 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
05:13:09 : =======Cancel button click : m_nStep(5)
