Thats not my log file, that is one that was posted in this thread, I posted it to show that line 76 is as far as I can get. Once line 76 hits it will be 4%, then I get the connection thing, no matter what I do when it restarts it will start the update process over, then FAIL at the same spot
I was thinking DarkTremors a2sd may be the issue, but before I bricked I had wiped and nandroided to my stock nandroid. No matter what makes this phone FAIL, if this works for 9 out of 10 phones it is still a success! Heck if it fixes half it is still awesome! I was hoping I could make it work, as there are a few things I want to try with the S (firerats) but am even more leery now, lol. The only logical reason I can come up with for the FAIL is the way I applied the update. I took it from the phone cache, moved it to sd card, rebooted recovery, flashed it to my stock nandroid. It verified and started installing, it was looking goog, lol. Then when it reached its end it asked me to finish install by rebooting using menu or pushing power if I recall correctly. I chose menu, as soon as I push reboot system it said writing radio image, then went straight to the silver LG/ICON screen where it has been since. If I boot the phone it will bootloop, every 5 minutes or so the phone will flash black and the silver LG will come right back, like a bootloop. I am tempted to do the VC update to my replacement and roll back to V9 and re-root, perhaps I will go buy a new usb cable first, just to rule that out
My replacement phone is CRAZY, I can clock to 864 stable! But I keep it at 806
