javascriptvoid
i also found out to today you got to be patient with this damn lg screen it might take it 5minutes to get past the boot screen but it will and now im back to normal thanks peeps
23:03:15 : ****************CheckAndDownload****************** **
23:03:15 : ******Extract Start LS670ZV9.cab*****
23:03:15 : Model Dll Dir(C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\)
23:03:15 : ExtractInfo Error(0)
23:03:15 : Extract cab file error.
23:03:15 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone] ???丮 ???? ?õ?
23:03:15 : RemoveDirectory1 Error(2):C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone
23:03:16 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
23:03:16 : CLGMobileHttp Class ?Ҹ????.
23:03:16 : CLGMobileHttp Class ?Ҹ?...
23:03:16 : Page_Error ?κ??Դϴ?
C:\KP500-Utils-EN-v0.4.2>dir *.cab
Volume in drive C has no label.
Volume Serial Number is A847-58B1
Directory of C:\KP500-Utils-EN-v0.4.2
02/25/2011 11:10 AM 99,220,700 LS670ZV9.cab
1 File(s) 99,220,700 bytes
0 Dir(s) 12,293,926,912 bytes free
23:03:17 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
Are you on the right thread? It seems you are following the directions to revert to V9 using KP500 in diag mode, but you are posting in the thread about unbricking by using KP500 in emergency mode.*EDIT* I just realized that I have no service anymore
Which problem are you currently having? No service or not being able to get KP500 to complete?
Done.SFHUB: You should make THIS it's own thread. If you don't want to, I will
Much thanks to all of you good people. I finally got UnBricked!
I had installed VC through the LG updater. Installed Thunderom 1.7.0. Life was good. Then I turned the phone off, and BAM. LG brick. My situation was compounded by the fact that even with my wife to help press buttons, I could NOT get the Emergency Mode screen to turn on. It just sat there with a blank screen. With the hard buttons at the bottom lighting up though, I figured What the hell... Using the VC wad wouldn't work for me. After getting to 99% it would error out and no boot. I tried the V9 and it errored out again at 99% only this time, my phone went into the 'Battery Required' Screen. I put the battery in and it went to the charging screen. Figuring What the hell, I tried to boot into recovery. Success! Flashed to Stock Rom and recovery just to be safe and upgraded to V9. So far so good. I've reboot and Shutdown completely with no ill effects.
The big thing for me was that even though the 'E-mode' screen wasn't on, I was still able to get the k500 to see the 'E-mode' function.
Cheers!
Can you clarify Note #3?I got a brick here too. Experiencing the same black screen issues as others are reporting. Don't see nor can I get into a visible E-Mode, just a blank screen and the bottom buttoms illuminated.
I've recovered this phone twice while messing with it. Here's a few of my observations:
1. Remove the SD card!
2. If the LG updater tool keeps throwing up on you at 4%, try removing the battery, disconnecting the USB, then reconnect the USB and press retry at the same time. (do not power up the phone) If the updater gets past 4% after doing this, then reinsert the battery. It successfully started uploading the firmware for me afterwards
3. If pushing the ZVC firmware still results in a brick, downgrade back to ZV9. This unbricked for me. However, I removed thunderc and restored the stock recovery ROM, then tried to upgrade to ZVC. Bricked again!
If anyone's got links for how to thoroughly remove ThundeROM and Thunderc and upgrade to ZVC, i'dappreciate it!
I'm starting without the battery in; is that why it's puking on me at 4%? I've tried pushing V9 and VC and they both stop at 4%. Do you remember how you plugged it back in? Were you in e-mode or just normal? With or without the battery?
I feel like I'm SO CLOSE to unbricking this beast. Thanks for your help.
