basketthis
im not a wiz at this type stuff so thanks but im still lost. i need a for dummies version lol im scared i will ruin my phone if i attempt that
My suggestion is to give it a try. Its the best way to learn. The instructions also include links if you are confused. The commands listed after the steps are the commands that you will use to flash the recovery. If it seems to complicated for you, I suggest just holding out until the process becomes easier, reading through other threads to become familiar with the terminology, or just waiting until a more simplified guide comes out (unless there is one that I am unaware of that already exists). Again, trying it on your own is probably best. But, if you are comfortable, there will be a solution/help soon I'm sure!
BTW, it is not necessary to unroot to apply the newest gingerbread update... You can simply update.
