HawkFish707
Okay, cool. I have access to a windows Machine, and I can install the tool. But I'm at V9 so I wouldn't be Reverting, I need to update to VD, does the tool do that?
If you want to end up at VH, just make sure you have stock V9 recovery and you are fine to run through the Rooting ZVH instructions. Actually as part of those instructions, if you follow every step, it'll make sure you have V9 recovery.Okay, cool. I have access to a windows Machine, and I can install the tool. But I'm at V9 so I wouldn't be Reverting, I need to update to VD, does the tool do that?
If you have Xionia CWMA recovery, try doing the shortcut.On the install of stock recovery I am receiving the error for out of space... I am using the commands cd /sdcard/000root , then the /system command as is written on the instruction. Any help would be appreciated thanks
busybox df -k
ls -l /system/bin/flash*
It might be. Havent messed with it yet but I plan on trting it now. So after busybox df -k I put ls -l/system/bin/flash install_vd.sh???
will tell you how much space is available in your various partitionsbusybox df -k
will tell you the file size of /system/bin/flash_image (that's an asterisk after the "H" in flash)ls -l /system/bin/flash*
cd /sdcard/000root
ls -l
Your flash_image looks ok.
The only other thing that could be going wrong is you have a corrupted recovery image.
Can you type the following and copy/paste the full output
Also can you post the exact command you typed in adb shell to flash the stock recovery. Cut and paste also that also, preferably after you run it, along with error message. I want to make sure there are no errors there, so telling me you typed it as in the instructions wouldn't be helpful.
If you are using cmd prompt, press [alt][space] to get the menu, then Edit->Mark, mark the text using point and click, then Edit->Copywhats the command used to copy and paste the full log?? is it just ctrl+c and ctrl+v? and I will get that soon as I can don't really have that much time to mess with it. just trying to unroot so I can trade it in and get some cash for it.
