It is possible that there is some error in the recovery partition's flash memory. Flash memory can get bad sectors to.didnt work it says no space left on phone! i have friken 6 gigabytes on sd and 100 mb on phone itself and it says what i said a couple seconds ago i will try from hydro rom maybe it will work on there it worked last time im so bloody fustrated
Glad it helped.OMG..Thanks so much! I thought I was going to miss out on such a great phone, but you made it so easy. I couldn't possibly thank you enough. Yay. Thanks for this great and easy tutorial..or whatever its called. I'm so glad I didn't throw my phone away! If I could kiss you, I definitely would. Thanks again!
Do you already have Stock Recovery? If so, skip that step.I get stuck on ADB Shell. I get error...
- exec '/system/bin/sh' failed: No such file or directory (2) -
check_LGE_official: fopen(/sdcard/ally_security) error
I run adb devices and it shows up as...
A10000193DB202 Recovery
My brain is pretty much gone at this point.
I'm terribly new at this.
My brother helped me root my LG Optimus S so I'm not even certain how to use "adb shell" or "terminal." I'm fairly certain I have a "Stock Recovery" since my phone will only boot to ClockworkMod Recover v3.2.0.1 and from all the reading I've done I think that qualifies as a stock recovery.
I've never flashed a rom, or done anything remotely fancy with my phone since rooting. In an effort to reduce bloatware and open up space I tried a factory reset. Bad idea.
I was running ZVH software and continually getting a "software update" notice on my phone. I'm guessing this is for ZVJ but I could find no way to get there.
Anyhow, I've tried to follow these steps for about 6 hours. I'm stuck on step 3. I can run the update.zip but the lines read:
ClockworkMod Recovery v3.2.0.1
--Install from sdcard...
Finding update package...
Opening update package...
Installing update...
(Here it hangs for roughly one minute, then adds
Install from sdcard complete.
I cannot seem to get it to proceed to "write the radio,boot android, or recreate davlik cache"
I'm at my wits end and desperately need help. I can't do my job without my phone. Please be kind and thorough since this post is not for lack of effort.
Thank you in advance.
Sounds like xionia or armor ra or possibly the rom manager recovery. Before u flash u need to make a backup if your doing update use stock recovery provided and run update manually.
Sent from futuristic optimus s
Are you running a custom rom? In your recovery, how many options do you have. Stock has 4 options. You MUST be on stock recovery to run an update.zip like that.
