Originally Posted by
along541 and then what
If you can get into recovery, go into mounts, mount the sdcard, open up the sdcard on your computer, then transfer the Rom over and unmount it. Then wipe data, cache, dalvik-cache. Then you can flash the Rom! And it will work!
I feel like we are jumping around so much because you still have not explained your situation very well. It's hard to assist anyone if they can't describe their situation...
