09-05-2011 10:57 AM
51 123
tools
  1. along541's Avatar
    I factory reset my phone now it wont resart it keeps going to clockwork mod recovery and i backed it up but now it wont start up just keeps going back there
    09-04-2011 05:37 PM
  2. along541's Avatar
    well i first put this clockmod on then did factory reset
    09-04-2011 06:09 PM
  3. along541's Avatar
    thought it would take it off but didnt
    09-04-2011 06:09 PM
  4. basketthis's Avatar
    Nope. Sure won't.
    09-04-2011 06:15 PM
  5. basketthis's Avatar
    There's an unrooting and returning to stock process in the hacks and roms section.
    09-04-2011 06:16 PM
  6. along541's Avatar
    nope theres not
    09-04-2011 06:27 PM
  7. jondevere's Avatar
    nope theres not
    Yes there is.
    http://forums.androidcentral.com/lg-...urn-stock.html
    Follow that if u need it. This is the return to stock thread he was speaking of.
    09-04-2011 06:30 PM
  8. along541's Avatar
    all i did was factory rest why would i just keep going here
    09-04-2011 06:30 PM
  9. jondevere's Avatar
    so what u are saying.. is you did a factory reset from within Recovery?
    09-04-2011 06:31 PM
  10. jondevere's Avatar
    If you did a factory reset within recovery you now need to wipe dalvik and cache and flash a new rom. You just deleted your ROM. Thats why its not booting
    09-04-2011 06:33 PM
  11. along541's Avatar
    it wont let me do that
    09-04-2011 06:35 PM
  12. jondevere's Avatar
    in recovery you need to flash a new rom. Otherwise it will NEVER boot again.
    09-04-2011 06:35 PM
  13. along541's Avatar
    it wont let me download those files
    09-04-2011 06:51 PM
  14. along541's Avatar
    that forum is pretty much trash because it wont let me get those files
    09-04-2011 06:54 PM
  15. jondevere's Avatar
    What do u mean? U can download roms from that forum. I've been around a long time. Trust me u can.
    Sent from my PG86100 using Tapatalk
    09-04-2011 06:58 PM
  16. jondevere's Avatar
    Choose a ROM. Download it and place it on the root of your SD card.
    Don't unzip it. Just copy it to the SD card.
    09-04-2011 06:59 PM
  17. basketthis's Avatar
    What forum is trash? Your point is not coming across at all.... I just don't understand what you are saying...
    09-04-2011 06:59 PM
  18. along541's Avatar
    um this thing lg calls a phone or dumb *** clockwork mod wont let me
    09-04-2011 07:11 PM
  19. basketthis's Avatar
    Hmmmm... Not understanding what point you are at. Can you take a couple of minutes and type up a chronological list of what you have done to get to the point you are at? Here's an example:
    1. Rooted phone
    2. Installed recovery
    3. Installed Rom
    4. Went into certain menu and clicked this thing
    5. It asked me for my name
    6. I didn't type my name
    7. Now its broke
    Also be specific about everything including menus, pushing buttons, and flashing things...
    09-04-2011 07:19 PM
  20. jondevere's Avatar
    Did u use clockwork mod from the market and install the recovery and try to install a rom!!!!
    09-04-2011 07:22 PM
  21. jondevere's Avatar
    If you dont like that phone feel free to send me it. The Optimus S is an all around AWESOME phone.
    09-04-2011 07:23 PM
  22. jondevere's Avatar
    Did u give up?
    basketthis likes this.
    09-04-2011 08:48 PM
  23. along541's Avatar
    ya i gave up
    09-04-2011 09:14 PM
  24. along541's Avatar
    the problem is i need new rom but it wont let me install anything
    09-04-2011 09:16 PM
  25. along541's Avatar
    always gets aborted
    09-04-2011 09:16 PM
51 123
