Hi All,
I was wondering if anyone has an answer to this. I use a bluetooth headset with a2dp streaming. When activating a call using voice calling, the default volume for the voice commands is set very low.
There is no adjustable volume for bluetooth voice commands in call. I can only adjust the volume on the side rocker on each call, which is a hassle.
Once the call connects, the call volume is fine.
This issue is that there is a separate setting for bluetooth in call volume.
Does anyone know of a way to set a default for this volume to the maximum?
