STOP
and read whats below
The ZVD update broke the ability to wirelessly tether for free. Please do not make a thread to discuss why this disappoints you and why you really need it. We get it lol we love free tethering too!!!!! You do have some options.
1) Force flash back to a previous version. Thread can be found HERE. Please do not discuss this method here. Read the force flash thread and ask any questions in that thread.
2) Root your phone, which also requires fore flashing an old version, but then allows you to flash custom ROMs after you flash a custom recovery. That thread can be found HERE. Please do not discuss this method here. Read the root thread and ask any questions in that thread.
-Wired Tethering-
3) If you don't want to force flash, and don't want to root then you do have the option of using an app like easy tether from the android market. The app is free to try, one time fee of $10 if you want to buy. Again, this is wired tethering, not wireless.
STOP
and read whats above
I apologize in advance for the misleading title but something has to be done to try and reign in all the threads about wireless tether not working anymore . The fact of the matter is wireless tether works just fine ... if you pay for it. for those who'd rather not pay for it, your options are above.
Please note, the options above are the only options if you want wireless tethering for free. We're (the development community) not holding back some super secret way that with 1 click gets you back up and running. This is it. You either follow the instructions, or pay for it monthly through sprint, or use wired tethering.
Once you are opn VC or V9 software, the instructions to tether are below. Again THIS WILL NOT WORK ON SOFTWARE VERSION VD
Open Menu > Settings > about phone > if SW Version = LS670ZVD then this process will not work for you. WARNING WARNING!!!
This does not require root and works on rooted and non-rooted phones alike.
go the market and get the free application "Hotspot Widget" by Harald Muller. Any hotspot widget should work but we'll use Haralds in this example. After it downloads do the following:
1) long press a blank spot on your screen and select add a widget.
2) press Hotspot Widget
5) Now click your new widget
