808rides
I'm a little confused.
On a stock V9 Optimus S, there is a settings menu option
Menu->Settings->Wireless&Networks->Portable Hotspot
If I enable this, the blue hotspot icon shows up in the status bar and the hotspot seems to be working with a PC.
Is there something that this widget is doing beyond what is built in?
I'm on rooted stock VC and this works for me as well. Even allows WPA2 PSK excryption. And it's fast, I'll try speedtest it, but it feels a lot faster than using the wireless tether for root.
Thanks for pointing this out!
