1. mike9670's Avatar
    My new LG Optimus doesn't play with Ford SYNC like my old Sony W580i.
    No voice commands or anything. I think I can recieve calls via bluetooth and can manually dial numbers from the dash keypad but that seems about it.
    11-26-2010 03:52 PM
  2. Kevin OQuinn's Avatar
    Ford needs to update the sync software to support the phone.
    Sent from my T-Mobile G2
    11-26-2010 04:18 PM
  3. kinster02's Avatar
    Did you update your software to the lastest version by going to syncmyride. com.
    11-26-2010 05:33 PM
  4. maru2001's Avatar
    Which of the newer ROMs work best with Ford Touch? CM7 had a non unique BT MAC address and I have to have unique because my wife and my phones will be pared at the same time and MFT needs unique MACs.
    02-06-2012 02:03 PM
  5. epidenimus's Avatar
    I seldom use Bluetooth, but have you tried any of the stock-based ROMs? If you're on ZVD, give Reborn or sROM a spin.
    02-06-2012 03:10 PM
  6. maru2001's Avatar
    I was on ZVD with CM7 but I upgraded to H so I could try Hydro. I guess I will be going back to D so I can use MFT if that's my only option. Or I might just wait for the 2013 update at the end of this month and see if things work with ZVH.
    02-06-2012 04:26 PM
