1. gogetter20002's Avatar
    My wife and I both have the Optimus S. I set up hers to use the wifi when at home and it works great. I set mine up the same way and it keeps disconnecting. I utilize an "N" router and am only a couple of feet away from it. It shows signal as being excellent. User manul is no help in troubleshooting. The 1st night I used the wifi, it work great and fast. Have not been able to use it at home well since. I used it at a friends house and had no problems there. Any advice?
    12-12-2010 06:01 PM
  2. c1phr's Avatar
    Because of the instability of the N specifications, especially with non-N devices (ie, the Optimus S) it is a good idea to try turning your router to B & G hybrid mode in the settings and disabling N. I know a friend of mine has a laptop that supports N, but can't hold a connection here without me turning N off.
    12-12-2010 09:47 PM
