1. mdwright1032's Avatar
    I have owned lots of devices and phones. I know some batteries work better if you keep them charged while others work best when you run them down low and then do a full recharge.
    What is best?
    01-08-2011 04:50 PM
  2. hamagc's Avatar
    I believe I recently read an article on gizmodo that explained smart phone batteries don't like to be drained completely.
    01-08-2011 05:09 PM
  3. trekkie1701c's Avatar
    Keep it charged as much as possible.
    If you have to (for some reason) not use the phone for an extended period, drop the battery down to 40% before putting it in storage.
    01-08-2011 06:10 PM
  4. nealoc187's Avatar
    Read this thread, in particular the posts by the original poster byrong, and Toysrme257th on the 3rd page of the thread.
    Your battery gauge is lying to you (and it's not such a bad thing) - xda-developers
    digitallove and xtacocorex like this.
    01-09-2011 06:24 PM
