Turn on your camera on the left side pull down the menu go to settings and to camera sounds and select no sound
Download Estrongs file explorer (free) from market. Give it Root access in settings. navigate to /system/media/audio/ui/ and rename camera_snapshot.ogg to camera_snapshot.ogg.bak and then when you take pics there won't be any shutter sound.
My shutter sound goes away if I put the phone on vibrate by turning the ringer volume all the way down. Is that permanent enough?
the above instructions will permanently remove sound, even if ur phone is off vibrate.
yes. You can't remount /system writeable without root, and that's the only way it can delete the files.Doe this mean BEFORE you use the app you need to have root access? I've tried this however with no root access it simply says it 'failed'?
Michael
