Wifi connected to network, but wont load
iridealittlebike
Okay, so my Optimus S is connected to the network via wifi, but it wont load any pages. I have reset my router already and forgotten/connected to the network to see if that helped but nothing. I know the connection to the network is fine because I can use winamp wireless sync, but thats it. I tried updating the PRL and Profile but that didnt work this time. Any suggestions?
moburne
5
if you have wireless security enabled on your router try turning that off and see if it connects then. more than likely you have mistyped the security passcode on your optimus.
iridealittlebike
Never mind I got it. I just had to set a static IP as stated in an above thread, but I changed the IP from ***.2 to ***.4. If anyone else is having this problem try it out
pauloxcavalcante
