1. GJOKER's Avatar
    Got a problems while trying to root my LG Optimus S.
    Using this tutorial http://forum.androidcentral.com/lg-o...works-too.html
    When I put in "adb shell" I get an "error: closed"
    What does it mean?
    Help me out.
    I just got my phone replaced by Sprint and it got the new LS670ZVD version of a software on it. I need to tether the internet ASAP.
    05-17-2011 03:38 AM
  2. itsjareds's Avatar
    Maybe try restarting the server? Run the command 'adb kill-server' then 'adb start-server'
    Another option is to restart the phone and see if that helps too.
    05-18-2011 07:49 PM
  3. the_maplebar's Avatar
    I had the same problem today. Tried restarting the server, and messing around with settings. Finally worked after I restarted my PC.
    05-18-2011 09:43 PM
  4. GJOKER's Avatar
    Restarted Computer and it did not work
    Restarted the phone after a computer restart and it worked.
    Now I have successfully rooted LG Optimus S.
    Thanks guys.
    BTW itsjareds. I believe the commands are "adb killserver" and "adb startserver", no space or line between the words.
    05-19-2011 09:03 PM
  5. the_maplebar's Avatar
    Congrats, I just got my Optimus rooted today also.
    05-19-2011 09:54 PM
  6. GJOKER's Avatar
    yeah, I had mine for a while with a previous version of software and was using wireless tether widget with no issues, than all of the sudden my speaker and mic stop working, so I take it to Spring and they give me new phone with new software on it.
    But it's all good now since I was able to root it.
    05-20-2011 06:11 PM
  7. JonnyRedScarf's Avatar
    I have killed the adb server, and started it back up again. I restarted both my phone and my computer. Still getting the "error:closed" return after 'adb shell' command. Is there anything else I can try? I have the VM670 Optimus V, and Virgin Mobile has refused to release ANY Android Updates. So I need to root my phone.... Any help would be appreciated greatly...
    02-02-2012 08:19 PM
  8. Ez Duzit's Avatar
    No need to mess with adb. Try either of these automated root apps depending on your software version. Both install to your pc and are pretty much one click root solutions that do exactly what they're supposed to do. Use the correct one for whatever radio you have. But no guarantees with the Optimus V.
    One click Root for ZVD Only (Froyo)
    http://forums.androidcentral.com/lg-...-platform.html
    One click Root for ZVH or ZVD
    http://forums.androidcentral.com/lg-...y-1-0-1-a.html
    02-03-2012 02:17 AM
  9. extatic's Avatar
    I'm having the same issue.. can anyone tell me how they resolved it? the kill,start server i tried and it didnt work, i restarted phone and pc multiple times, 1 click root method i cant find for my specific phone (LG L55C from straight talk)..
    When i type adb devices i can see the phone.. when i adb shell it gets "error: closed" i cant use the LG ESTEEM root from area51 because of the error : closed thing..
    Anyone have any ideas on how to resolve this?
    09-14-2013 09:16 AM
