1. wrigty12's Avatar
    Hey There, so I have been trying to find some way to be able to customize the LED colors for the F7.
    1) Light Flow did not do anything.
    2) Light Manager never changed the color, but would actually bring up the default color for the notification (even when I had them off)
    3) LED Tester was able to have the LED display different colors, but unfortunately not apply to notifications.
    Has anyone successfully found a way to change the color options?
    12-30-2013 06:32 PM
  2. Randall Donahoe's Avatar
    Im pretty sure you cant uness LG releases an update for them
    12-31-2013 11:47 AM
  3. Beth Leiva's Avatar
    Not going to happen.
    01-02-2014 09:08 AM
  4. sp0r412's Avatar
    I have my led customized. I have a different color for every notification.
    I rooted with framaroot.apk Gandalf exploit
    Installed SuperSu which after granted superuser uninstalled the exploit.
    Next installed greenify with donation package for experimental features.
    From the experimental features I installed Xposed framework which allows you to customize your phone with a whole myriad of mods without changing your stock Rom.
    Installed Xblast Tools mod which allows you to customize your led a million different ways. I also have a translucent status bar just like KitKat while still running 4.1.2. I don't like the lg launcher so I use Nova Prime for a much another user experience.
    Screenshot is.gd/lgf7screen http://i.imgur.com/mR7h116.jpg
    Sent from my LG-LG870 using Tapatalk
    UJ95x likes this.
    02-24-2014 07:07 PM
  1. Need help finding stock rom please.
    By Zach Fedt in forum General Help and How To
    Last Post: 12-31-2013, 02:26 AM
  2. Kies is gone from my phone and wont connect to PC via USB Please Help!
    By Rick HKS in forum General Help and How To
    Last Post: 12-31-2013, 12:12 AM
  3. Wallpaper Customizing
    By Irishgator in forum Google Nexus 5
    Last Post: 12-30-2013, 05:44 PM
  4. Samsung Galaxy S4 Custom Recovery/ CyanogenMod Help!
    By drooskiii in forum Legacy Android & Other OS's
    Last Post: 12-30-2013, 04:57 PM
  5. Note 3 notification app sounds help
    By SuspectZEROification in forum General Help and How To
    Last Post: 12-30-2013, 02:08 PM
