1. Justin King2's Avatar
    How do I fix My keypad on my phone I have the word answer and not it is not working.
    04-06-2015 03:16 PM
  2. SpookDroid's Avatar
    Not sure what you're trying to do here :S What do you mean by 'word answer'? Is this your lockscreen password not being accepted? If so, you can reset your password via the Device Manager. Just log into play.google.com from a PC with the same account that's on your phone, select the Gear icon, and select Device Manager.
    https://support.google.com/nexus/answer/3388218?hl=en
  3. SpookDroid's Avatar
    04-06-2015 03:53 PM
  1. What app is good for reading SMS to me while I'm driving?
    By mothershipload in forum Google Nexus 6
    Last Post: 03-29-2016, 11:06 AM
  2. Replies: 1
    Last Post: 04-08-2015, 07:21 AM
  3. Replies: 1
    Last Post: 04-07-2015, 07:18 PM
  4. Padlock swipe and pin no excessive!
    Last Post: 04-06-2015, 04:20 PM
  5. Are Android phones compatible with usb connection on Toyota vehicles?
    By AC Question in forum More Android Phones
    Last Post: 04-06-2015, 02:54 PM
