07-18-2012 06:01 PM
131 ... 23456
tools
  1. exProphecy's Avatar
    So.. how come I got a 3600mAh one and I have never hit 3 days even on light use. On light use I was only able to get 30 hours at most. What's going on?
    09-18-2011 05:15 PM
  2. jdcnosse's Avatar
    It's possible that they lied about the size and that it's misprinted on the battery, or more likely maybe it's a cheap battery that doesn't hold a charge very well.
    I was reading somewhere about a 3500mAh battery for the EVO 4G and that the people writing the comments found that their battery life got better after a couple rundowns of the battery (like charging it to 100%, letting it get to 10-15% before charging again). Kinda like getting the battery up and outta bed and ready for the long haul.
    09-18-2011 07:25 PM
  3. one80oneday's Avatar
    Yea mine isn't lasting very long either but I think it's because I'm overclocking with custom ROMs. Still better than stock battery though and I'm already used to its bigger size.
    09-18-2011 09:49 PM
  4. ke4jgx's Avatar
    Just checked mine again on this charge 10 hrs 10 min and am at 85% I'm overclocked to 768 max and 600 min. normal usage will see what i get out of it total and report back. Thats with wifi on and 3g off using green power.
    i agree that the 3600 maH battery is probably mislabeled or just cheap batteries that won't hold a charge. a 3600 maH sould be more than twice as thick as a standard battery and I would think even thicker than a 3000 maH battery. Depending on the battery density it *could* be the same thickness as a 3000 . i doubt it tho. I'm no expert on batteries, just going on my own observations.
    I've some rechargeable batteries for my LED flashlight and the higher capacity AA's are a tight fit in the light and it seems to hold true in most cases i have seen.. Just for curiosites sake what's the thickness on that 3600? I have 9mm thickness on this 3000 maH
    09-19-2011 01:03 AM
  5. zedorda's Avatar
    Have u wiped ur battery history/stats?
    09-19-2011 11:16 AM
  6. Vishwar's Avatar
    Thank you for sharing the coupon. This coupon A20CM can also be applied to many other cellphone extended batteries we are selling. We will also add more extended batteries for Android phones.
    You guys should send me a commission check for all of the batteries I just sold for you.
    jdcnosse and Emstan like this.
    09-19-2011 01:08 PM
  7. jdcnosse's Avatar
    Still waiting for mine, although the tracking number says it'll finally be leaving Hong Kong today. Well probably between 8pm and 8am tomorrow morning (the 24th, as it says it'll be leaving Hong Kong on the 24th...but they're twelve hours ahead of EDT). I'm excited for it! haha
    09-23-2011 05:34 PM
  8. Diablo2k's Avatar
    Anyone pay extra for AirMail? how long did it take to get the battery?
    09-26-2011 04:54 PM
  9. jdcnosse's Avatar
    I paid extra for the tracking number...but only because I like to follow my packages
    I figured I could tell my story as an average approximation for how long it might take.
    I ordered mine on September 13th at nearly 2am EDT. Received the e-mail that it had shipped Sept 14th at 11pm EDT. Got the e-mail with the tracking number Sept 15th around 11pm EDT. According to the tracking number my package left Hong Kong on the Sept 24th. I'll update when I receive it but so far that's roughly 2 weeks from time of order to now. I'm not complaining, the battery was a good deal, and as long as it arrives within a week from now I'll be happy
    EDIT: It arrived!
    So it only took about 2 1/2 weeks. lol
    09-26-2011 05:46 PM
  10. skuly's Avatar
    I ordered two of the 3600mAh batteries from ebay and they came within 2 weeks but i had them sent to my brother who lives in awhile away from me because i bought one for him, and he came to visit today and gave me my battery so im charging it now, my black rubber case on it doesn't fit anymore but at least it still fits in clip-on pouch/case.
    10-01-2011 07:59 PM
  11. jdcnosse's Avatar
    It's not as fat as I thought it would be. Then again this is my first android phone, I'm used to fat and cheap feature phones (Samsung Intensity, Samsung Smooth, LG Rumor 2)
    Also seemed like I was able to get slightly better reception. This could just be a placebo effect though.
    10-02-2011 02:17 AM
  12. Vishwar's Avatar
    They still haven't sent me a commission check..
    10-04-2011 01:41 PM
  13. danthemanohhyea's Avatar
    I ordered a very similar battery off amazon the other day. Chose that one over the one in this thread because it ships out much sooner and isn't coming direct from overseas so shipping time itself is 3-5 days.
    Lets hope it's worth $20.
    10-04-2011 11:49 PM
  14. dlaxtn2's Avatar
    hi I was wondering what the final test results were for the 3600maH battery did those end up proving to be better on battery life then the 3000s did.
    10-09-2011 03:43 PM
  15. one80oneday's Avatar
    I have 3600mah and it doesn't seem as good as 3000mah. I only get about 12-15 hrs per charge.
    dlaxtn2 likes this.
    10-09-2011 04:39 PM
  16. dlaxtn2's Avatar
    That's how much I get with my stock battery
    10-10-2011 05:03 PM
  17. Eollie's Avatar
    If your willing to tear it apart I would bet you will find bad cells and/or very underrated cells. I know you know how to reset bat stats and recal them so something is not right with that battery pack.
    10-10-2011 05:22 PM
  18. thexxoffspring's Avatar
    On the website with the battery, for shipping it says "Free shipping" and then there is also "Registered Airmail." Now with the "Registered Airmail you pay $2.49 to get a tracking code. But the part that confuses me is it says "Processing time 2-3 business days.) Registered Airmail with tracking code 10-20 business days." What does the 10-20 business day mean? Also is there a site that I can buy this from that will ship within a week? I know Amazon can but the highest battery life I could was 2800 mAh. Any help?
    EDIT: I'm conifdent I'm going to get the 2800 mAh off of amazon. I cant imagine there is a significant difference in 3000 and 2800. I'll post back when I get it!
    EDIT 2: Just found out it'll take 17-28 days to get here... is there any other place I can buy from where I'll get it in at least a week?
    10-11-2011 09:20 PM
  19. danthemanohhyea's Avatar
    I bought this one off amazon:
    Amazon.com: 2800mAh Mobile Battery For LS670, Optimus S Extended With Back Cover: MP3 Players & Accessories
    I ordered it 9/30/11 and received it today 10/11/11
    It was supposed to get here in 3-5 days, but that didn't happen. I'm charging the battery now and then doing a calibration so we'll see how long it lasts.
    EDIT:
    The price seems to have gone up since I bought it. I only paid $20 shipped for mine. I bought it because I didn't want to wait forever to get it, but I ended up waiting a long time anyway. If I were to do it again, I'd buy the one listed originally in this tread.
    10-11-2011 10:50 PM
  20. ke4jgx's Avatar
    2-3 days means thats how long it will take for them to fill the order the 10 to 20 days is how long it is expected to get to you AFTER the order is filled. took about 2 weeks to get mine.
    10-12-2011 08:00 PM
  21. zedorda's Avatar
    I ended up ordering a 2nd 3000mAh battery. The first one only took 9 days from placing the order and receiving it. This second one took 18 days but had like 4 more customs dept. stamps on it. It didn't seem as well put together either. I know these are just cells sticker-ed together but it was funny. The bottom plastic plate was loose in the bag but stuck back in place when pressed back in, the sticker wasn't even put on straight. I had to peel it off abit and replace to straighten it out so it covered the metal. It works fine and u can't even tell anymore that it was so bad when I got it. After getting done fixing it I had a sudden thought of customs agents tearing my battery apart looking for drugs and/or WMDs. Had myself alittle chuckle.
    10-13-2011 08:25 PM
  22. camf3xu's Avatar
    how is this phone size while using 1 hand? better, worse for texting? im considering buying this but dont want a paperweight in my hand that doesnt fit comfortably
    10-13-2011 11:00 PM
  23. ke4jgx's Avatar
    It fits quite well in the hand. i like it better than the original, it makes it easier to hold but is no so bulky as to make it awkward.
    I've made my own cradles for it to use it the house and the added thickness doesn't seem to affect the phone holder in the car's ability to hold it securely. It's awesome as heck to go days between charges. no more always having to carry a charger around and worry if the dang thing is going to make it thru the day.
    10-13-2011 11:27 PM
  24. thexxoffspring's Avatar
    lolz
    10-14-2011 12:21 AM
  25. thexxoffspring's Avatar
    EDIT:
    I ended up ordering this one too. Right now checking the tracker it is in Brooklyn NY. I live in Rochester NY so I imagine it'll come tomorrow or Monday. So excited to get it!
    10-14-2011 12:25 AM
131 ... 23456
