1. IronWill's Avatar
    For you guys and gals that upgraded from a Rumor Touch it should be noted that the batteries are cross compatible. The other night I decided to pop one of my two Rumor LGIP-401n batteries out and compare it to my Optimus LGIP-400n and they are the same fit. Now I'm lucky enough to have three batteries for my Optimus which is a very good thing as I use Digitally Imported "DI" Radio, a Live Wallpaper, and an 864Mhz clock 24/7.
    07-27-2011 05:33 AM
  2. zedorda's Avatar
    What is the mAh?
    07-27-2011 10:46 AM
  3. IronWill's Avatar
    1250mAh....
    07-28-2011 11:25 PM
  4. watskyhotsky's Avatar
    1250mAh....
    well how much does it sell for? if you can buy the battery cheaper than the OV battery it might be a good one to have laying around as a backup.
    then again there is that 3000mAH extended battery :P
    Vishwar and jdcnosse like this.
    07-29-2011 01:39 AM
  5. kcls's Avatar
    Wow, this is great! I hadn't even considered that it might fit! Thanks a bunch!
    08-13-2011 09:21 AM
  6. gladesofsummer's Avatar
    Haha it doesn't even fit right
    Sent from my VM670 using Tapatalk 2
    06-08-2012 05:41 PM
  7. tdm's Avatar
    So very close. It fits but not quite perfect. I could see using it in a pinch...
    06-13-2012 12:08 AM
  8. diecastdonkey's Avatar
    Yes I noticed this after upgrading to the V and was siked to have a backup battery but it just popped out every time. Basically the same battery but an older design and less charge.
    06-14-2012 07:47 PM
Tags for this Thread
