1. Ph1Man's Avatar
    I want a little extra battery life out of my Optimus V, but don't want to use the extended batteries discussed elsewhere because of the extended backs (I need my case to fit). So I have 2 questions.
    1. What is the largest capacity\best battery that will not require a new back-plate, and fit the Optimus V without mods?
    2.The best I could find is an AceSoft 1800mAh, does anyone have experience with AceSoft batteries in general and, if you own this battery can you verify it is 1800mAh and good quality?
    Battery link: Amazon.com: New 1800mAh Battery and AC/USB Desktop Charger for LG Optimus S LS670 / Optimus V VM670 / Optimus M MS690 / Optimus T P509 / LG Optimus U US670 / Optimus C LW690 CellPhone: Electronics or Search amazon for 1800mAh Battery and AC/USB Desktop Charger for LG Optimus S.
    Thanks,
    Ph1davies
    01-26-2012 01:41 AM
  2. Jakethedrummer's Avatar
    Get yourself this
    Deal Trees and Encerspay45 like this.
    06-26-2012 02:15 PM
  3. zedorda's Avatar
    If you only need one.
    Anker 1600mAh Battery for LG Optimus V VM670, Optimus M MS690 | eBay
    I have these and they seem to get more life than the extra 100mAh would allow.
    06-28-2012 08:42 PM
  4. Jakethedrummer's Avatar
    Yeah they are awesome, and cheap too!
    06-29-2012 04:59 PM
  5. niftypixel's Avatar
    How long a life on average were you getting with these out of curiosity?
    07-14-2012 01:19 AM
  6. Jakethedrummer's Avatar
    Around a day or so with moderately heavy use, data, GPS, texting, and the camera are constantly being used throughout the day
    Sent from my Tapa-Talkin, Gingerbread runnin LG Optimus V
    08-03-2012 10:18 PM
  7. Leemann's Avatar
    If I buy this battery are there any mods that need to be done, Also can it charge the stock battery?.
    08-17-2012 11:43 PM
  8. Jakethedrummer's Avatar
    No, I know for a fact if you purchase the one I posted it will work completely stock, and yes the charger will also charge the stock battery
    Leemann likes this.
    08-18-2012 02:57 PM
