1. wolong's Avatar
    I was very frustrated with how fast the battery would discharge on my VS920 Spectrum. Anyway, I saw that eBay offers a bigger, high capacity, inexpensive battery for the Spectrum, along with a special cover that enables the thicker battery to be used. I LOVE IT. Works great. This is a MUST accessory for the Spectrum! My spectrum is now a bit thicker but I actually like the feel better.
    03-20-2015 12:10 PM
  2. Rukbat's Avatar
    I prefer two batteries. Run one down to 40% and, if I can't charge it, swap them. That gives me twice the capacity of one battery, the same thickness (in case it matters, like for a case) and a high-quality normal capacity battery is usually cheaper than even a cheap higher-capacity battery.
    But now, buy a cheap universal charger (they're available for under $10 - I use this one) and keep the original battery charged and in your pocket (in a plastic bag or, if the larg one came in a soft plastic case, that case, so it won't get shorted by money or keys) and you'll have a spare. Even if you don't need it, once a month, put it in and use it until it's down to 40%, then put the big one back in and charge the spare. One day, when you're down to "get to a charger fast" time with the larger battery, you'll have the spare in your pocket.
    (And if you want the batteries to last, never drop them below 40% if possible. See The Care and Feeding of Lithium Polymer Batteries.)
    03-20-2015 01:41 PM
  1. Battery life abysmal the past 2 days.. Otterbox??
    By SweetSaudade in forum Samsung Galaxy S5
    Last Post: 08-19-2015, 10:46 AM
  2. Xperia Z1 Compact started to randomly swith off ar battery level around 35-40%
    By Kristaps Abele in forum Sony Xperia Z1 Compact
    Last Post: 03-30-2015, 12:00 PM
  3. Replies: 1
    Last Post: 03-19-2015, 11:16 PM
