how to increase phone call volume on lg stylo 4
  • Thread starter Android Central Question
  • Start date
A
How can I increase the phone call volume when it's all the up. When I'm on a call the person sounds very low. How can i fix this?
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
It is what it is. If you can find an earphone or headphone with an amplifier, or just an inline amplifier, that would work. But there's not much you can do with the phone itself unless you want to start playing in the internals (which could result in a dead phone if you don't know what you're doing) - there's a sound profile xml file you can change settings in to change carious (phone, media, etc.) sound levels in. (Look for help with that at XDA (https://forum.xda-developers.com/showpost.php?p=64194807&postcount=5, but I'd start slow - go up to 30 first and see what the effect is, then you'll have an idea of how the number relates to the sound level).
