    I have and LG Stylo 4 and my flashlight and camera flash wont work. When i click on the flashlight icon in my notification bar it says it on but it isn't. I even downloaded a flashlight app and when i went to use it it crashed and said unfortunately home has stopped. It did that every time. When im on snapchat or my camera and i put flash on it wont flash either. I want to hear every possible solution before thinking of a factory reset. All help is appreciated!!
    01-29-2019 04:43 AM
  2. belodion's Avatar
    Try Safe Mode.
    01-29-2019 05:23 AM
  3. Zake_sake2580's Avatar
    Try Safe Mode.
    I did try that and it did the same thing
    belodion likes this.
    01-29-2019 07:20 AM
  4. Rukbat's Avatar
    The camera module is most likely bad - and the LED (which is what the "flash" is) is probably also bad. (It sounds as if the phone may have suffered some damage to that part of the phone - maybe by dropping it?) The bad parts would have to be replaced (in a shop - this isn't a do-it-yourself project).
    01-29-2019 11:44 AM
  5. tiffanyhill876's Avatar
    If I were to replace the rear camera would that fix the flash? Is the flash in the camera or is it another part? Is there anyway to get the part name or number I need to buy? Thank you.
    01-02-2020 06:02 AM
  6. B. Diddy's Avatar
    Are you planning on doing the replacement yourself? I'd recommend bringing it to a repair shop, where they can figure out exactly what needs to be replaced.
    01-02-2020 01:12 PM
  7. tiffanyhill876's Avatar
    I'm doing it myself and I've already found the part. I know that's what's wrong because when I replaced the screen I used a little to much force on the camera and it popped out on the floor. I found the camera and it stated the LED flash was included so I'm gonna get it and see. I just wish I could get a better camera for it. Thanks anyway.
    01-03-2020 07:49 AM
  8. B. Diddy's Avatar
    Ah ok, good luck!
    01-03-2020 09:56 AM
  9. tiffanyhill876's Avatar
    Ah ok, good luck!
    Thanks
    01-03-2020 12:08 PM
  10. Shotgun Bro's Avatar
    I Hit mine gently with my hand and it fixed ps I have LG stylo 4
    12-22-2020 05:23 PM
  11. belodion's Avatar
    Yes, a judicious smart slap is sometimes effective.
    Welcome as a new member.
    Shotgun Bro likes this.
    12-22-2020 06:35 PM
  1. Uploading photos from Mac to pixel 3 and have them appear in albums
    Last Post: 01-29-2019, 12:35 PM
  2. Replies: 2
    Last Post: 01-29-2019, 11:49 AM
  3. Camera Problem
    By Android Central Question in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 01-29-2019, 04:53 AM
  4. Why Gyroscope is not working ?
    Last Post: 01-29-2019, 04:23 AM
  5. hi my phone is currently on 7.1 and its lagging my instagram videos out
    Last Post: 01-29-2019, 04:19 AM
