    Hi, I'm using an LG Stylo 4 and I have a really particular problem.
    When you plug in a USB-C charging cable to this device, a little animation plays at the bottom of the screen near the charging port while it briefly dims the screen. Seems harmless enough.
    My problem comes in whenever I unplug the charger. The device repeatedly shows that animation, including the screen dimming, at random intervals when the device is unplugged. Restarting the device resolves the issue, but it comes back again whenever I plug in and unplug the device.
    Additionally, when the battery usage screen is open, the Google Play Services entry will flicker to its long-form file name for 1 frame every time the charging animation plays.
    Has anyone had this issue, if so, how did you fix it?
    03-17-2020 06:35 AM
  2. mustang7757's Avatar
    Try safe mode if it does the same ?
    'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    03-17-2020 10:37 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Make sure the charging port is clear of any debris by blowing it out with a can of compressed air, and also clean the contacts with a Q-tip dipped in rubbing alcohol.
    03-17-2020 12:37 PM
  1. Playing any new games on your phone?
    By Ry in forum General News & Discussion
    Last Post: 06-10-2020, 08:42 AM
  2. Continuous chime charging notification
    By Private user in forum Ask a Question
    Last Post: 03-19-2020, 03:05 PM
  3. Is there a cable that will hook-up with my Moto Z Play Droid and a tv?
    Last Post: 03-16-2020, 03:40 PM
  4. Firefox OS environment on MODERN DEVICES!
    By milleniumdroid in forum General News & Discussion
    Last Post: 03-15-2020, 08:01 PM
  5. Can I play movies on an SD card on my Samsung Galaxy Tablet A?
    Last Post: 03-15-2020, 11:51 AM
