concensus ?
opinions on battery saving programs
In the past I've used shut app with my old note 4. Recently it was pointed out to me that programs like this really don't make a difference as they use up battery themselves. What do most of you do? Is a battery saving program a good idea? Has anyone used one that they feel makes a real difference?
Re: concensus ?
I don't use any. I don't feel they work.
Re: concensus ?
Thanks
Re: concensus ?
Most of the built in battery saving features of the new phones have made those apps obsolete.
That and just common sense.
Don't have unnecessary apps running in background and keep screen brightness reasonable.
The screen on time is what drains battery most so if the power drain is minimized when the screen is on you get more life.
Re: concensus ?
Originally Posted by
MittenSportsFan Most of the built in battery saving features of the new phones have made those apps obsolete.
Ok but do I have to keep going into app manager and clearing data? So far I've had google chrome and you tube stop working and I've had to go clear the app data. I've only had the phone since last Sunday so that seems odd
Re: concensus ?
ansa82 Ok but do I have to keep going into app manager and clearing data? So far I've had google chrome and you tube stop working and I've had to go clear the app data. I've only had the phone since last Sunday so that seems odd
It may be something going on with Chrome and You tube (both Google properties). I have had both stop recently on other devices (iPhone 6+ and Moto Turbo).
I try to keep only a few apps open at any one time.
Re: concensus ?
MittenSportsFan It may be something going on with Chrome and You tube (both Google properties). I have had both stop recently on other devices (iPhone 6+ and Moto Turbo).
Thanks. I try to close all after I use them also
