Save big + get 3 months free! Sign up for ExpressVPN today
  1. bigpapa7272's Avatar
    I bought a dual port 4.8a car charger but found it doesn't support fast charge. Can anyone recommend a good car charger with fast charge for the v10?
    11-10-2015 04:23 PM
  2. one0one951's Avatar
    I bought an Aukey Quick charge 2.0 from Amazon and can verify that it works. I cannot however post a link.
    11-10-2015 04:40 PM
  3. bigpapa7272's Avatar
    Thanks
    11-10-2015 07:17 PM
  4. ajb1965's Avatar
    This! It's less than 10 bucks and works great
    Posted via the Android Central App with an awesome V10
    11-10-2015 07:39 PM
  5. rankar7's Avatar
    if you're getting the double one, i'd get the aukey with the dual fast charge usb ports. there's another out there that only has one 2.0 fast charge port and the other usb port is a standard output port.
    Laura Knotek likes this.
    11-11-2015 08:26 PM
  6. stan23's Avatar
    The aukey one works great! It even has a led to show that you're on fast charge. Green for fast charge and blue for regular charging.
    BBerry2ADroid likes this.
    11-11-2015 08:39 PM
  7. IHateMyTreo's Avatar
    Mine just arrived. Model No. is CC-T1. $15.99 on Amazon. Nice construction, solid. Would post link and photo but I don't have high enough post-count yet.
    11-12-2015 06:41 PM
  8. mrgiven's Avatar
    http://www.amazon.com/Qualcomm-Certi...cUvbUpU4828532
    That's the one I ordered. Should have it Monday next week. I'll update as to how well it works
    11-13-2015 05:59 AM
  9. boogas8's Avatar
    http://www.amazon.com/Qualcomm-Certi...cUvbUpU4828535
    That's the one I have. Works great for me. I also bought their fast charger battery pack.
    11-13-2015 06:04 AM
  10. udazavlanje's Avatar
    Except for their USB cable. It was useless after a few weeks.
    via AC App on
    VZW Moto X DE/N7
    11-13-2015 09:32 AM
  11. BBerry2ADroid's Avatar
    The Aukey from Amazon should be here tomorrow.
    LG V10. Posted via the Android Central App
    11-17-2015 11:19 PM
  12. Laura Knotek's Avatar
    http://www.amazon.com/Qualcomm-Certi...cUvbUpU4839547
    I have that one and use it to charge my Moto X Pure Edition. It's great.
    11-17-2015 11:21 PM
  13. Vizi's Avatar
    Just picked this up.
    11-18-2015 12:24 AM
  14. mrgiven's Avatar
    Let us know how that performs
    11-18-2015 09:43 AM
  15. Vizi's Avatar
    I've only had them for a day, so far they work well. They have an LED light that indicates whether the device is fast charging or normal. The build quality is petty is solid. The car charger has a soft touch feel to it. They came in separate packaging w/ 6ft cords. The phone recognizes both of them as fast charging. There it's a constant LED even when there isn't a device connected. I don't care for that very much. I haven't done any speed comparisons yet.
    11-18-2015 11:27 AM
  16. mrgiven's Avatar
    How do you know if it's "quick charging?"
    11-18-2015 12:57 PM
  17. Lewis Zephyr's Avatar
    I got the Aukey from Amazon. Comes with a cable and it does engage fast charge:
    http://smile.amazon.com/gp/product/B...ilpage_o05_s01
    @mrgiven it will say so on the notification drop list.
    11-18-2015 01:04 PM
  18. Mason BlitzWolf's Avatar
    there's one better than the aukey, i'm using this. can't post link too, check the pic.fast charge car charger-111.jpg
    11-18-2015 10:27 PM
  19. Vizi's Avatar
    While charging, settings - battery. It will tell you there.
    11-18-2015 11:02 PM
  20. Ed_Grohl's Avatar
    Lock screen will tell you.
    11-19-2015 08:44 AM
  21. BBerry2ADroid's Avatar
    I got the Aukey two-port charger yesterday. Seems pretty fast so far. No visible LED lights on this one.
    Here is the link: http://www.amazon.com/gp/product/B01...cUvbUpU4842959
    I would recommend it.
    11-19-2015 10:14 AM
  22. mrgiven's Avatar
    The aukey two port 30w charger works well. Every time I've hooked up it charges at just over 1 amp.
    11-19-2015 01:00 PM
  1. Charging my S6 Edge+ with a battery bank.
    By Kristopher S in forum Ask a Question
    Last Post: 11-24-2015, 03:37 AM
  2. Charging my S6 Edge+ with a battery bank.
    By Kristopher S in forum Samsung Galaxy S6 edge+
    Last Post: 11-11-2015, 09:33 AM
  3. Replies: 1
    Last Post: 11-11-2015, 12:53 AM
  4. Replies: 0
    Last Post: 11-10-2015, 04:16 PM
  5. Replies: 0
    Last Post: 11-10-2015, 09:23 AM
