1. migaux's Avatar
    I currently have the HTC ONE (M8) and one of the things I didn't like is the notification led. It only has a single color so I can't assign different colors for different notifications. ALSO, it doesn't blink at all while its charging, which I hate.
    I'm undecided between the LG V10 and the S6 Edge Plus. Aside from the notifications on the secondary window, does it have a multicolored notification light?
    While I'm at it, anyone know if the S6 Edge Plus does?
    11-24-2015 03:41 PM
  2. felloffthetruck's Avatar
    V10 has no LED notification light at all. Why LG would leave this off on the V10 is beyond me.
    11-24-2015 03:46 PM
  3. gibbga's Avatar
    Yea, there isn't a notification light, but you don't really need it. If you get a text, email, call, etc the icon of item stays on the second screen instead. I'm fine w/o the notification light because of that.
    Borarjti likes this.
    11-24-2015 05:58 PM
  4. ajb1965's Avatar
    I don't mind the lack of led because the second screen does a decent job, but I did like how you could set custom colors for people's SMS notifications on the G4.
    11-24-2015 09:33 PM
  5. felloffthetruck's Avatar
    If the main screen is off and the second screen is real dim, do notifications brighten up the second screen when they come in?
    Or do you have the light the main screen just to see them?
    11-24-2015 09:46 PM
  6. ajb1965's Avatar
    I don't believe it does. I just tested it. It does get brighter in certain circumstances, but I honestly don't know what triggers that. I've never really given it much thought because I see the dim display fairly well.
    11-24-2015 10:00 PM
  7. JayWill's Avatar
    I believe the design intent was since there is an always on notification ticker that a notification LED would be redundant.
    11-24-2015 10:13 PM
  8. migaux's Avatar
    There is no notification light at all. Still a decent phone.
    02-19-2016 11:04 AM
  9. kramer5150's Avatar
    Settings > Accessibility > Hearing > Flash Alerts
    Toggle it ON and it will flash the main LED with incoming calls and txt.... but thats all it does. It doesn't indicate battery charge or anything like that, and it certainly is not multi colored.
    02-19-2016 11:50 AM
  1. white square in notification menu
    Last Post: 02-28-2016, 09:27 PM
  2. Does the S6 Edge Plus have a RGB notification led? Single Color?
    By migaux in forum Samsung Galaxy S6 edge+
    Last Post: 12-11-2015, 04:52 PM
  3. I have a Note 5 may go to a Note 4
    By amyf27 in forum Samsung Galaxy Note 4
    Last Post: 12-08-2015, 12:38 AM
  4. Is there any way to center the home screen?
    By Bloodthirsty in forum Motorola Droid Turbo 2
    Last Post: 11-24-2015, 03:52 PM
  5. Replies: 3
    Last Post: 11-24-2015, 03:48 PM
