1. KillerQ's Avatar
    Try this... Hold your phone sideways as if it's in your jacket pocket. Then cover to top sensors of the phone.... The power button wont turn the phone on.
    That explains why you can't push power in my pocket as I bring it out.
    That sucks.
    01-09-2016 04:36 PM
  2. anon(782252)'s Avatar
    That's the way the proximity sensor is supposed to work. Otherwise you would turn the phone on and off hundreds of times a day in your pocket.
    SaintlySins likes this.
    01-09-2016 05:15 PM
  3. KillerQ's Avatar
    True...
    But mY iPhone 6 allows me to press the power button in my pocket and it turns on... This would be nice on the v10 since it takes forever to wake up anyhow....
    Also, the way the v10 power button is designed, it would rarely turn on in a pocket, if at all.
    Thanks!
    01-09-2016 07:26 PM
  1. How did I keep google widget from opening a new instance every time I use it?
    By Native Cheese in forum Android 6.0 Marshmallow
    Last Post: 01-11-2016, 12:29 AM
  2. Replies: 3
    Last Post: 01-10-2016, 01:30 PM
  3. AT&T ZTE pay as you go phone.
    Last Post: 01-09-2016, 06:17 PM
  4. How do i move apps to the sd card
    By Greggory McCarthy III in forum General Help and How To
    Last Post: 01-09-2016, 06:14 PM
  5. Replies: 1
    Last Post: 01-09-2016, 06:13 PM
