1. ansa82's Avatar
    At one time I saw a fix to get the increased volume and premium sound without plugging in headphones but I can't find it? Anyone?
    01-13-2016 01:25 PM
  2. CountryDevil's Avatar
    Not sure if this is what you are talking about or not. But I have not seen anything that allows you to use the DAC without headphones. Not saying it is not there, just have not seen it..
    http://forums.androidcentral.com/lg-...ml#post4905860
    01-13-2016 04:14 PM
  3. Joeykool's Avatar
    Lookup dac fix for lg v10 in play store.
    https://play.google.com/store/apps/details?id=com.phascinate.lgv10.dacfix
    01-13-2016 06:05 PM
  4. michael hester1's Avatar
    I play my mine through my old carver amp.with a headphone jack to rca imput
    01-13-2016 06:26 PM
  5. mbryanr's Avatar
    DAC fix is the only thing I know of, and requires to be plugged in.
    Posted from my LG V10
    Joeykool likes this.
    01-13-2016 06:54 PM
  6. kramer5150's Avatar
    Pretty sure the 32 BIT DAC is activated only when it senses the presence of TRS plug. I guess an awkward way around that is an external speaker plugged in, or a TRS-RCA "Y" adapter into a hi-fi line-in.
    01-14-2016 09:22 PM
  7. Joeykool's Avatar
    I didn't know it had to be plugged it...is there any sense having it then? Doesn't the installed dac work the same way? Thanks
    01-15-2016 09:54 AM
  8. mbryanr's Avatar
    The DAC fix allows all apps (not just the LG supported apps) to utilize the HiFi DAC. It doesn't change the plug in requirement. BTW, only Sony has the codec to transfer via Bluetooth lossless audio.
    01-15-2016 10:46 AM
  9. thisisjason's Avatar
    By default the hi-fi DAC only works with some apps, even with headphones plugged in. On other apps it would use the Snapdragon DAC instead. The DAC Fix app gives you access to the DAC in all apps.
    The DAC/Amp only works with wired connection (i.e. headphones or aux). It could never work with wireless connection (DAC means digital to analog converter after all, while bluetooth is still a digital signal). I doubt it's possible to use it with the internal speaker either, not that such a poor quality speaker would benefit from it anyway
    Joeykool and Ntchwaidumela like this.
    01-15-2016 10:52 AM
  10. Joeykool's Avatar
    Thank you
    01-15-2016 11:26 AM
  11. kramer5150's Avatar
    Well... Look at it this way, a wired connection is the only way to truly capitalize on the potential. Bluetooth is compressed/lossy so it would be pointless feeding it with a 32 BIT data stream. The V10 speaker is not capable either. In either case the benefit of 24-32 BIT data would be inaudible.
    EDIT... Just found out the V10 is APT-X compatible. I have never used it before, but APT-x is supposed to be a less-compressed BT audio codec. An apt-x device might benefit from a higher resolving DAC process.
    01-15-2016 11:51 AM
  12. ansa82's Avatar
    https://play.google.com/store/apps/d...e.lgv10.dacfix
    Thanks!
    01-15-2016 06:54 PM
  13. ansa82's Avatar
    Thanks!!
    01-15-2016 06:57 PM
  1. I never received offer how do I check my confirmation for a reason?
    Last Post: 01-20-2016, 04:30 AM
  2. Best Way To Backup
    By dlcpa in forum LG V10
    Last Post: 01-13-2016, 04:26 PM
  3. How do I transfer contacts?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 01-13-2016, 01:12 PM
  4. Replies: 0
    Last Post: 01-13-2016, 01:03 PM
  5. HTC One M7 seems to be bricked - any way to recover data?
    By frenchimmersion in forum HTC One M7
    Last Post: 01-13-2016, 12:19 PM
