I've gotten so many telemarketing junk calls the past few days. How do i block these??
the White Pages app can help.
And of course, you can block numbers manually after you realize they're junk. At least they can't call you back. Well, they can, but it won't ring. Might leave a VM.
what ralfyguy said.
White Pages ID is a caller ID app with a social component. So it can help provide you information on the caller, and can help you and the community mark calls as junk. If you get a call the community has identified as spam or junk, the White Pages ID will show that for you and let you choose to answer it or not.
So you can block the number on your phone after you've identified it as junk, and you can also optionally use White Pages ID to help others know it's junk and then also maybe know the next one's junk before you answer it.
You don't need an app. It's built in. Go to your Phone app and tap on Call Logs. Tap the offending number and then tap the menu in the top right corner. Select Reject Call.
This is all i get when I'm on the offending # and press the 3 dots in upper right hand.
Here is what I mean
Verizon you can do it from your account online. Works great.
Download Call Detector from the Google Play Store. Works great. I have the paid version, 1.49 a month to not put up with telemarketers is worth it!! You can also add manually also.
Call Blocker is a good, free app that simply picks up and then hangs up. The caller doesn't hear anything. Not even a ring on their end. Your phone doesn't ring, and does not allow the caller to leave a voicemail. It is manual. Once you determine telemarketers or unwanted calls, Simply add them to the block list.
I dont have that option. Must be a Verizon thing
