So I am having some trouble with my LG V10 I purchased in January. As this is my first Android phone, I am a little out of my element and looking for some help.
The Situation: I had a fair amount of apps installed. 6 email accounts (5 manual sync, 1 push) Facebook, Twitter, and linkedin for social. If I let my phone sit for 8 hours unused, I was between 8% and 10% an hour of battery usage. I was using apps like greenify and other task manager apps to remove unwanted background apps. Cellular, WiFi, and Bluetooth were the only radios on. The only Google stuff syncing was apps, contacts, and chrome.
What I have done: I did a factory reset as this started shortly after I pulled the MM trigger (I am on the Verizon Marshmallow release) and was still at roughly 6% /hr burn with no usage. This was with zero emails and social networks setup. I started getting drastic. First, I turned on airplane mode. I deleted every app I could. Verizon cloud, Verizon protection, Verizon Message+, LG Fitness App, Amazon Apps, Google Music, Google Video, Google App, and a couple handful of others. I turned off the second screen when the main was off. That got me to 5% /hr burn.
So I thought to myself, maybe it is the user interface, launcher, or some other hidden process, so I shut my phone off and let it sit for a few hours. I turned it on, and to my surprise, I was burning battery at roughly 4.5% /hr.
Last step…so I thought the batter had developed a short. Used my second battery on the same tests above, confirmed. So today while I was at work, I had no battery in the phone. When I came home 9 hrs later, popped the battery in and it had the same charge as when I left for work.
So where I am at I see one of two problems causing my issues
1.) A software FUBAR. I am hoping there is a way I can do a total reflash. Basically the equivalent of reformat the HDD and reinstall fresh.
2.) A hardware short.
Obviously I am hoping it is the former, as the latter involves working with Verizon/LG.
Any help would be greatly appreciated, or pointing me towards a post that solves this. I have looked but come up with bupkis.
Thank You.
06-07-2016 10:09 PM
