1. AC Question's Avatar
    My other v10 needed a power button which I replaced but I can't figure this one out unless it has more than one issue
    04-22-2017 12:57 PM
  2. gipper69's Avatar
    The expedient thing to do is to insert a charged, good battery. That way you can eliminate bad charger port. If it doesn't boot with a fresh battery, it is likely to be dead and then you get to determine what part failed. I would presume you are beyond any factory warranty.
    04-22-2017 05:03 PM
  1. My display clock time is wrong im trying to fix itmy
    Last Post: 04-22-2017, 12:37 PM
  2. Hi i have a problm on my SanDisk sd card
    Last Post: 04-22-2017, 12:35 PM
  3. How do I load the set tv app on the shield?
    Last Post: 04-22-2017, 12:27 PM
