Save big + get 3 months free! Sign up for ExpressVPN today
  1. batu9802's Avatar
    My new lg v10 f600s phone Weak connection wifi even in the same room with wifi router . No warranty i don't know what i do please help
    P.s. Carrier signal very good and my os 7.0 lg stock f600s and my other phone and tablet Connecting to WiFi normally
    Screenshoot is taken while same room with router
    07-10-2017 05:29 PM
  2. B. Diddy's Avatar
    Moved from the Nougat forum to the V10 forum.
    Have you already tried rebooting the router by unplugging its power for 10 seconds? If that doesn't help, see this guide for more ideas: http://forums.androidcentral.com/amb...-problems.html
    Does this happen on other wi-fi networks as well?
    07-10-2017 07:36 PM
  3. batu9802's Avatar
    Yes i do rebooting router
    07-11-2017 04:50 AM
  4. B. Diddy's Avatar
    Did you try the other tips in the guide? And does the same thing happen on other wi-fi networks?
    07-11-2017 11:19 AM
  5. batu9802's Avatar
    Yeah i try and other devices is normal
    07-11-2017 11:26 AM
  6. B. Diddy's Avatar
    My question was if the same thing happens when you use other wi-fi networks (like at your local library or coffeeshop), not if other devices work normally on your wi-fi network.
    07-11-2017 11:59 AM
  7. batu9802's Avatar
    İ will try i am at home but my phone cant see other neighbors wifis
    07-11-2017 12:28 PM
  8. batu9802's Avatar
    This part flex in back bezel mising Does it effect wifi Wifi signal problem v10 f600s-45159.jpg
    07-13-2017 04:34 PM
  9. B. Diddy's Avatar
    Not sure. How is it missing if the phone is new? Or did you get it used? Or did someone give it to you?
    07-14-2017 11:23 AM
  10. batu9802's Avatar
    İts new but gift someone give to me but I think it used because flex part mising
    07-14-2017 12:29 PM
  11. B. Diddy's Avatar
    Find out where your friend got it, and bring it back there. A new phone shouldn't have parts missing.
    07-14-2017 04:59 PM
  12. batu9802's Avatar
    I opened the all parts Okey but back frame flex mising
    07-14-2017 08:19 PM
  13. wess580's Avatar
    I'm having the same issue started last month
    07-19-2017 10:27 PM
  14. batu9802's Avatar
    So still same?
    07-20-2017 05:29 PM
  1. After reset wifi won't show ant networks why?
    Last Post: 07-10-2017, 03:43 PM
  2. Android update problem
    Last Post: 07-10-2017, 01:56 PM
  3. problem with gmail doesn't send or receive mails
    Last Post: 07-10-2017, 09:53 AM
  4. nexus 5x heating problem after july security patch update
    Last Post: 07-10-2017, 06:24 AM
  5. Can't log onto public wifi
    By Double Tap in forum Samsung Galaxy S5
    Last Post: 07-10-2017, 06:20 AM
