Save big + get 3 months free! Sign up for ExpressVPN today
  1. lateck2's Avatar
    Hello all.
    I had a battery in my V10 swell up. So much that it pushed the back apart.
    A little background. My back up V10, not used for some time, stored in the house. I did a full factory reset and wipe of the phone and 200gb card. All normal.
    Noticed the battery level at 60%. No problem. Put it on one of my Anker 2.0 chargers that I have used with the V10 and my Tab S2 ( no problems ).
    I noticed it said it would take 9 hours to charge. I did not worry, fluk I thought.
    An hour later noticed it was charged. I also noticed that the back was separated from the fingerprint button(?????). Pulled the back and yes the battery was swollen. Strange.
    Anyone else have this problem? I don't have a photo but will try to remember tomorrow.
    Lateck,
    10-03-2017 11:39 PM
  2. kixfan's Avatar
    Wow! This is the first I've heard of this with the V10. Was it the original LG battery? If so it's close to 2 years old so it could be the battery age. Could also be an issue with the Anker Charger as well or a combination of both. Scary stuff though especially after the Note 7 thing.
    10-04-2017 07:29 AM
  3. chanchan05's Avatar
    Probably a problem occurred when it was stored. Some chemical reaction. The recharging then triggered the swelling (formation of gas).
    10-04-2017 08:02 AM
  4. lateck2's Avatar
    I'll post a photo later this morning so everyone can see it's real.
    The battery is not the original but it is a LG replacement that I got on promo when I bought the phone. So it is 2 years old (+/-).
    I stored the phone in my spare backpack in the house, temp 79/80°f and dry. Same as I store other phone batteries (V20) and flashlight batteries.
    Lateck,
    10-04-2017 08:22 AM
  5. chanchan05's Avatar
    We're not saying it's not real. But batteries are known to swell up when some chemical reactions take place. It won't necessarily happen all the time as it is a bit unpredictable. Just throw away the battery and get a new one.
    Laura Knotek likes this.
    10-04-2017 09:10 AM
  6. lateck2's Avatar
    chanchan05, thank you. Yes, I do realize chemical reactions happen.
    A little follow up. I had placed the battery ( an LG, BL45B1F with a date of 2015.11.16<L>) in the freezer at work for safety. I just pulled it out and it was back to normal. But as I am typing it is warming up and expanding again.
    I have attached a photo showing the bulge starting.
    Lateck,
    10-04-2017 11:10 AM
  7. citronbull's Avatar
    Trash it and get a new one. You don't want a Note 7 fiasco in your hands.
    10-04-2017 11:14 AM
  8. kixfan's Avatar
    I agree. Throw it away (or recycle it) and get a new one. It's not worth the risk.
    10-04-2017 02:15 PM
  9. lateck2's Avatar
    Thanks to all. I do agree and have removed the battery.
    I more wanted to let others know of this happening. It makes me pause on the new V30, it having a non-removable battery........
    10-04-2017 08:19 PM
  10. kramer5150's Avatar
    I have 3 batteries that did that. they're all 18-20 months old and are certainly at the end of their life cycle. I have since replaced them.
    10-09-2017 08:19 PM
  11. Mooncatt's Avatar
    If you haven't disposed of it yet, I wouldn't suggest throwing it away. If you have a shop in your area that can safely discharge them and dispose of them, that would be great. Tossing it in the trash as is, without discharging it completely to 0.0V (0% on the phone is not really a fully discharged battery) can risk a fire if it pops in the garbage.
    If you're feeling adventurous, you can search the web for how to properly discharge a Lipo before disposal. I will say don't use the salt water bath method. The salt corrodes the connections before it's empty, thus preventing a full discharge and the inability to get a reliable voltage reading when it appears done. It'll show zero on a multi-meter due to the corrosion.
    If you're feeling dangerous, there's also more... Spectacular ways of discharging batteries in a very uncontrolled way. I of course do not recommend using these methods. If you want to watch batteries being stabbed, shot, shorted out, etc, use YouTube for that.
    kixfan likes this.
    10-09-2017 10:39 PM
  12. Son Nguyen's Avatar
    Happened to me when I left a spare battery in my car in 100° weather.
    10-12-2017 10:29 AM
  13. lateck2's Avatar
    Interesting, Mooncatt......
    10-14-2017 08:42 AM
  1. Battery swollen
    By rjack22 in forum Samsung Galaxy S6 edge
    Last Post: 11-19-2017, 08:43 AM
  2. My Samsung Galaxy S6 Edge turns on and off non-stop until battery runs out.
    Last Post: 10-04-2017, 05:03 AM
  3. Extreme battery drain issue
    By Aphyllous in forum Samsung Galaxy S7
    Last Post: 10-03-2017, 06:28 PM
  4. OK Google standby battery drain
    By flyingkytez in forum LG V20
    Last Post: 10-03-2017, 11:10 AM
  5. why my phone suddenly dead when my battery still at 15% or more?
    Last Post: 10-03-2017, 05:00 AM
