1. rushmore's Avatar
    I have read and seen a few videos stating the V20's LTE and wifi reception are the best of any device so far this year, but nothing confirmed. The Note 7 reception for LTE was weak and the wifi seemed to struggle to the point the N7 got warm, which is odd for wifi.
    Main focus is LTE reception though, since that is a battery drainer if not good. Never thought of the Note 4 being great in that regard, but it is compared to the Note 7. Places I struggled or got no LTE data with the N7, work with the Note 4.
    10-21-2016 10:33 AM
  2. rushmore's Avatar
    Bumped this one, since when posted, hardly any Verizon devices out there yet.
    10-23-2016 03:48 PM
  3. Germanguy's Avatar
    Have the t-mobile version. Both LTE and WiFi receptions are top notch.
    10-23-2016 08:16 PM
  4. omgitselaine's Avatar
    AT&T here and no issues at all
    10-23-2016 08:21 PM
  5. naturecannon's Avatar
    I have no positive or negative remarks to make. Haven't travel enough around town with this phone to remark. As with rest of the phone, "It just works" < I think that should be the LG V20 slogan, instead of "play more". IT JUST WORKS!!!
    10-23-2016 08:33 PM
  6. juliesdroidsync's Avatar
    I have both right now and have been doing some experiments. I installed from the Play Store signal check Lite. I have found them to be nearly identical. The Samsung has been perhaps a little bit better.
    11-03-2016 12:05 AM
  7. orgelbau's Avatar
    It seems the v20 can utilize a weak signal better than the note.
    Jona005 likes this.
    11-03-2016 12:17 AM
  8. juliesdroidsync's Avatar
    How does one actually test that?
    11-03-2016 10:57 AM
  9. rushmore's Avatar
    Stream or download something. Weak signal with bad reception will show up then. The bars are not the measurement, but dBm signal is. Example is my Note 4 and 7 showed the same bars, but the Note 7 had 10 dBm less signal. Both Note 7s did the same thing and struggled. Note 4 does not.
    juliesdroidsync likes this.
    11-03-2016 11:19 AM
  10. juliesdroidsync's Avatar
    I'm not looking at the bars, I'm using the app signal check lite that shows dbm but I have not done it while I'm downloading something. I will try that good suggestion
    11-03-2016 11:46 AM
  11. Android_Lapis's Avatar
    I'm on Verizon, & the signal is definitely better than on my Note 7. I'm in a rural area.
    11-03-2016 12:20 PM
  12. Almeuit's Avatar
    I don't have a V20 but my friend / co-worker has one. The -dBm signal on his phone is the same as my Pixel (usually within 1 to 2 dBm). We sit right next to each other as well so same location pretty much.
    He has no issues streaming HD video and I don't either. I would say the V20 is just fine . Oh yeah forgot to mention.. are both on T-Mobile so comparing the same signal from the same towers.
    11-03-2016 01:54 PM
  13. Danfj40's Avatar
    I ride a ferry to work and with my old G3 lost signal every trip in two locations when streaming audio would stop and switch to 1X. With the v20 not a problem at all 4G all the way. Yes the G3 is old but one data point for those that are interested.
    11-03-2016 11:49 PM
  1. To all of those still on the wait list!
    By Pigman in forum Google Pixel & Pixel XL
    Last Post: 11-01-2016, 08:15 AM
  2. Hows your battery life?
    By Clocks in forum Google Pixel & Pixel XL
    Last Post: 10-26-2016, 10:00 AM
  3. Replies: 3
    Last Post: 10-23-2016, 04:57 AM
  4. Replies: 2
    Last Post: 10-22-2016, 03:56 AM
