1. SupraLB's Avatar
    I've only tried this for a day , but the battery really does last longer with battery saving mode under the location settings. Even better, my location is always really close. I would need to turn it on for navigation driving down the road, but I really don't need it for much else.
    I always noticed that "finding location" notification peeping in the status menu, so there is no telling how much it was draining the battery. I think Android lumps that category into "Android System" in the battery menu.
    Jeremiah Bonds likes this.
    10-29-2016 03:15 PM
  2. jamesrick80's Avatar
    You can still keep it on high accuracy..just turn on Qualcomm izat as well...and you save battery that way without the compromise of throttling your processor with the battery saving mode....
    This is how I keep mine and battery life is excellent...
    10-29-2016 03:20 PM
  3. Jeremiah Bonds's Avatar
    Does iZat save battery? I could never figure that out..
    10-29-2016 03:21 PM
  4. jamesrick80's Avatar
    Yes use it...watch and see how much it improves without throttling your processor...just attched a photo of my settings below my other post
    10-29-2016 03:22 PM
  5. sean8102's Avatar
    I just enable iZat on my AT&T V20, glad to hear that it improves standby time!
    10-29-2016 03:25 PM
  6. jamesrick80's Avatar
    Exact reason why the battery life on this phone beats my old note 7 even though its a smaller battery.....the improved 3DNAND UHS 2.1+ helps with battery conservation as well....too bad none of the reviews mention any of this.
    10-29-2016 03:27 PM
  7. Jeremiah Bonds's Avatar
    I always avoided it. Lol I wonder what would happen if I use battery saver and that.
    ***never mind. I think I had it on.. I remember putting it on this phone to test it out.
    10-29-2016 03:33 PM
  8. sean8102's Avatar
    Yeah I just benchmarked the read and write performance on my V20 and was really impressed with the speed. Beats the note 7 by a decent amount.
    GPS battery saving mode really works-1hipixel-disk-performance.pngGPS battery saving mode really works-screenshot_2016-10-29-14-32-52.jpg
    10-29-2016 03:34 PM
  9. X1tymez's Avatar
    If user need more information about IZat then read below. Never know about it until now .
    What is the Qualcomm iZat in Android's Location Settings
    naturecannon likes this.
    10-30-2016 01:34 AM
  10. SupraLB's Avatar
    I'm sticking with just the Battery Saving mode. I tried the IZat as well, and I started getting that annoying finding location notification peaking again.
    So last night, I went to bed with 100% charge, I woke up with 99% charge. It used to lose about 4-5%. The GPS was just too active draining battery I guess.
    10-30-2016 11:55 AM
  11. jamesrick80's Avatar
    I can literally go to bed with a 100% charge and wakeup with 100% and my settings are like what I said in my previous post...so maybe u have a rogue app that overuses GPS services or you are utilizing too many cloud services
    10-30-2016 02:14 PM
  12. Joeykool's Avatar
    Mine goes down overnight by a little, but I have smart lock enabled...not sure if that makes a difference
    10-30-2016 02:25 PM
  13. stackberry369's Avatar
    I went to sleep and 7 hours later my phone was still at 100%
    10-30-2016 08:21 PM
  14. ThiSidUp's Avatar
    How would one find that app and turn it off?
    10-31-2016 11:58 AM
  15. Jeremiah Bonds's Avatar
    Maybe download a battery monitor like GSAM Battery to pin point exactly what caused it.. But I'm not sure, someone else might have a better answer.
    jamesrick80 likes this.
    10-31-2016 12:28 PM
  16. jamesrick80's Avatar
    I was listening to bluetooth music on my bluetooth earphones for a whole hour and battery stayed at 100% this morning
    10-31-2016 01:34 PM
  17. tadpoles's Avatar
    I always use Battery Saving Mode unless I really need high accuracy (only for driving directions).
    10-31-2016 02:57 PM
  1. Clarification on Theater mode and alarms
    By wynand32 in forum Android Wear / Wear OS
    Last Post: 01-08-2018, 08:13 PM
  2. second screen doesnt work with nova.
    By swagglepuff in forum LG V20
    Last Post: 11-01-2016, 10:15 PM
  3. Battery anxiety
    By psteve2005 in forum Google Pixel & Pixel XL
    Last Post: 10-30-2016, 04:56 AM
  4. Note 4 - stuck on recovery mode
    By Gebalmighty in forum Samsung Galaxy Note 4
    Last Post: 10-29-2016, 09:49 PM
  5. my keyboard suddenly stopped working...
    Last Post: 10-29-2016, 02:51 PM
