Axi6Ne8us
Active member
Having very good battery life after installing the latest update. Also, manually setting screen brightness helps and switching WiFi to standby when phone is idle is a plus.
Found the culprit. Turns out I left GPS on by accident.No luck for me today as phone idle has burned up just about as much battery as the screen being on. Not sure why but probably one of those fluke days.//uploads.tapatalk-cdn.com/20170125/779ee6ffac3bec55becc554ec53e08d2.jpg//uploads.tapatalk-cdn.com/20170125/724f42b18d8cc51ad73d348ad52bb488.jpg
I leave mine on high accuracy (been testing it out for a last week or so) and mine is still decent. Maybe that's why I don't constantly get 6 hours of SOT like you. HahaFound the culprit. Turns out I left GPS on by accident.
Yeah it definitely drains the battery quicker. I couldn't figure out why I was having those spikes where the battery would just nosedive in standby mode. The GPS seems to be the top candidate for why that happened. You should turn yours off and see what a difference it makes.I leave mine on high accuracy (been testing it out for a last week or so) and mine is still decent. Maybe that's why I don't constantly get 6 hours of SOT like you. Haha
I tend not to have those nose dives.. But I also turned off WiFi scan and Bluetooth scan.. I'm on 20h with 4h30m SOT time and 26 percent left.Yeah it definitely drains the battery quicker. I couldn't figure out why I was having those spikes where the battery would just nosedive in standby mode. The GPS seems to be the top candidate for why that happened. You should turn yours off and see what a difference it makes.
That's not bad either.I tend not to have those nose dives.. But I also turned off WiFi scan and Bluetooth scan.. I'm on 20h with 4h30m SOT time and 26 percent left.
For an hour and 20 minutes only used 6%? Wow. But I've never tried any other battery saving methods. Besides not downloading Facebook amd Instagram previously I just used the phone and am pleased. I can't even imagine how much more I could squeeze out of the battery if I turned the second screen off completely which I never have tried.yeah, I'm not mad at this battery.. LOL we both came from the V10. Have you tried to turn off the wifi and BT scanning on GPS? Also, turn off location history on Google? GPS rarely uses any of my juice, it's weird. Waze only used 7% of my battery also. and a game I played for 1h20 used 6% - only 252mah.. WEIRD
Clearing the cache helps. I went from 4 hours SOT to 5.5 hours SOT.
Com.qualcomm.atfwd under Android system is Qualcomm's Wi-Fi display service. Almost guaranteed it ran rogue for some reason and caused your issues today.For whatever reason my battery life was atrocious today. First time I didn't make it home without having to power the phone off just so the battery wouldn't completely die. Looking at the stats Android system, Android OS, and Phone Idle really seemed to do a number as I was at 11% with less than 3 hours SOT! Crazy thing is the phone never overheated once in that time otherwise I would have probably restarted the device to see if that would've helped. //uploads.tapatalk-cdn.com/20170215/5567bac47a2f396875cf6d084ba246bb.jpg//uploads.tapatalk-cdn.com/20170215/eaee5bc3ed2195e0bba5e12b9d95a745.jpg//uploads.tapatalk-cdn.com/20170215/852458df2e03861ad4946b3f7974c988.jpg//uploads.tapatalk-cdn.com/20170215/68063b698718ae82bf0822beea5867a9.jpg
I wonder why then. I always turn Wi-Fi off as soon as I leave the house in the morning.Com.qualcomm.atfwd under Android system is Qualcomm's Wi-Fi display service. Almost guaranteed it ran rogue for some reason and caused your issues today.
