1. adam.bean's Avatar
    First month, was getting 15-20 hours battery life, now getting 8-12.
    No change in software or usage. Have noticed worse cellular signals though. Just today I went from 4g to no service when everyone else in the house (all vzw) remained 4g. Have seen this many times. Going to try a new sim card.
    Curios if others are experiencing any similar symptoms.
    Feels like the damn V10 all over again.
    12-25-2016 08:08 PM
  2. AtTheHop's Avatar
    Who is your provider?
    12-25-2016 08:14 PM
  3. adam.bean's Avatar
    Verizon
    12-25-2016 09:24 PM
  4. michael hester1's Avatar
    go to network settings make sure your not on globle.
    12-26-2016 11:48 AM
  5. Morty2264's Avatar
    I am sorry to hear that, OP! The kind of signal or network coverage you are receiving will definitely have an effect on your battery consumption.
    12-26-2016 12:01 PM
  6. adam.bean's Avatar
    Yeah I'm on LTE/CDMA, have played with all 3, haven't noticed a lot of difference.
    12-26-2016 12:41 PM
  7. rushmore's Avatar
    I am seeing and hearing other reports of weaker signal with the V20 on Verizon. Strange.
    12-26-2016 07:53 PM
  8. adam.bean's Avatar
    It's really odd. I'll be using my phone and watch it drop from 4g to 3g without me moving. My wife has an S5 and she never loses 4g when we're in the same location. Something definitely funky but honestly very similar to the v10.
    12-26-2016 10:12 PM
  9. Morty2264's Avatar
    Let us know if there is any change once you get your new SIM card!
    12-27-2016 09:42 AM
  10. anon(903870)'s Avatar
    Signal is super weak on ATT as well (In my office anyway). Lose signal or frequently sitting on one bar. Was never like that before.
    Jona005 and lsmachado like this.
    12-27-2016 10:09 AM
  11. sayf777's Avatar
    Different version of LG V20,different network, different country and I'm also experiencing the same thing.
    12-27-2016 02:45 PM
  12. Froggie229's Avatar
    I have never had the problem before with my v10 but every time I get in my car is says my signal is weak. Does anyone know how to boost this or why this is happening? btw forgot to mention this is a v20.
    12-28-2016 05:17 AM
  13. Jona005's Avatar
    I've experienced some pretty random battery life/signal decrease myself. I'm on AT&T. Haven't changed anything notable, but when I use the GPS on my phone I might as well have it plugged into the wall. I realize how and why GPS drains battery, but it seems to be getting worse everytime I use it.
    12-28-2016 06:53 AM
  14. rushmore's Avatar
    Signal pull with weak reception even for something as simple as GPS will quickly drain a battery.
    12-30-2016 09:32 PM
  15. Wonder Why's Avatar
    Anyone has try dial *#546368#*990# on usuall call mode? This is hiden menu. I dont know if it is work on another country,but it works well in Indonesia. After you call it,the black screen will show up,choose the most bottom,Field Test-> Modem Settings-> RAT Selection. And then you can choose which network you prefer to. Here it is the last screen after we choose Rat Selection;
    Attached Thumbnails LG v20 - Battery life and degraded cellular signal-capture-_2017-03-06-17-32-11.jpg
    03-06-2017 04:36 AM
  16. lsmachado's Avatar
    I'm having the same issue as well. I went to at&t a few days ago, and they ran diagnostic on it, and said there is nothing wrong with the phone. I had them give me a replacement SIM card, but it didn't change anything. I still barely get 1 bar, even though I can see the cell towers from my house. I don't think my battery life is what it should be, either (maybe 2 or 3 hours of SOT with nothing too intensive, mainly email and browsing these forums). On my Note 4, I could look at the battery stats and see if there were any weak cell signals (there would be red or yellow if the signal was weak, but I don't see that option with my V20).
    03-06-2017 08:44 AM
  17. rushmore's Avatar
    The V20 is actually weaker than my Note 4 for Verizon signal. It is about the same or a little weaker than the Note 7 was. Note 7 signal reception was not a strong suit for it.
    03-07-2017 08:27 AM
  18. Wonder Why's Avatar
    I don't know in another country, but if V20 run in 4G LTE (4G icon on the left side next to signal), it drains battery significantly here in Indonesia. That's why I often switch to GSM in some conditions although 4G is more reliable and faster
    03-07-2017 07:58 PM
  1. How to fix VZW Galaxy s7 battery life
    By Seth Mishne in forum Samsung Galaxy S7
    Last Post: 01-04-2017, 02:00 PM
  2. Replies: 1
    Last Post: 12-25-2016, 10:59 PM
  3. Can you turn off battery life display on "always-on display"?
    Last Post: 12-25-2016, 10:07 PM
  4. Music will not show up
    Last Post: 12-25-2016, 06:22 PM
  5. Default font is NOT the default one
    Last Post: 12-25-2016, 05:37 PM
