1. nizmoz's Avatar
    I just switched from AT&T to Verizon, and have the same LG V20, and it seems it goes through the battery faster than my AT&T variant did. Any ideas?
    02-21-2017 06:45 PM
  2. onnad's Avatar
    How's the cell signal?
    02-21-2017 07:18 PM
  3. nizmoz's Avatar
    3-4 bars usually where my AT&T had 1 bar.
    02-22-2017 11:16 AM
  4. flyingkytez's Avatar
    Did you remove and disable the Verizon bloatware? Verizon is notorious for doing that. Also, from my experience, it takes several weeks for the battery and software to break in (Android N learns from your habits I think?)
    onnad likes this.
    02-22-2017 11:51 AM
  5. onnad's Avatar
    I agree with the above poster, Verizon adds a lot of bloatware to their devices. Once all the bloatware is disabled and you use the phone for a bit you're phone will see your habits. Also check for the apps that sync a lot or are running in the background more. Some apps just are more power hungry than others. Keep up updated about how the change in carrier is working out for you
    02-22-2017 01:16 PM
  6. Brent Michael's Avatar
    I hate all the bloatware these phones come with these days.. Makes setting up phone a pain and just drains battery and resources unnecessarily.
    02-23-2017 03:38 AM
  1. Replies: 17
    Last Post: 03-14-2017, 09:06 PM
  2. I can't find the right SD card, please help!
    By Rikku Watro in forum Ask a Question
    Last Post: 02-25-2017, 12:41 PM
  3. Replies: 2
    Last Post: 02-23-2017, 09:10 AM
  4. Replies: 7
    Last Post: 02-21-2017, 08:03 PM
  5. Replies: 0
    Last Post: 02-21-2017, 05:52 PM
