1. christianttt's Avatar
    The battery I ordered from Alixpress for 11 dolars just arrived with a cheap wall charger.
    I'll use it occasionally only when needed. Is it necessary to drain it to 0 first and then fully charge it to make it work at it's full potential?
    What advice can you give me to use it safely?
    07-05-2017 02:05 PM
  2. flyingkytez's Avatar
    #1 do not use aftermarket external chargers, they are not certified and cannot control the correct amount of power current to the battery. It's best if you used the original LG external battery charger cradle. Doing so may decrease the longevity of your battery. You can go cheap but there's no guarantee what will happen.
    #2 letting your battery go to 0 is actually BAD for your battery despite the myths. It's best to keep the battery between 25%-80%. If you're storing batteries for long term, keep it at 50%.
    #3 best way to get it to it's fullest potential is to use it a few times to give time to settle in
    07-05-2017 03:52 PM
  3. christianttt's Avatar
    Yeah I guess it's too risky to use that cheap external charger. Maybe I will only charge both batteries on the phone, 1 at the time and I will keep the spare battery to use only at "emergencies".
    I've seen the original battery pack on Amazon, too bad they don't ship to my country.
    07-05-2017 06:58 PM
  4. Mike Dee's Avatar
    The extended batteries all recommend cycling the battery from full to zero 4 to 5 times before normal usage.
    I have a Droid Maxx several years old that still holds a good charge and I never paid attention to how low or how high it got.
    christianttt likes this.
    07-05-2017 07:58 PM
  5. Doug Moffat's Avatar
    I skimp on alot of things but never chargers or batteries.
    recDNA likes this.
    07-05-2017 10:10 PM
  6. christianttt's Avatar
    Is there a need to calibrate the batteries before or after using them?
    07-06-2017 05:04 PM
  7. Mike Dee's Avatar
    Don't really know for sure, but like I said earlier, the extended batteries recommend full cycling a few times when you first get them. They even go as far as to tell you to leave them on charge for two hours after they reach 100 percent which makes no sense to me.
    07-06-2017 09:29 PM
  8. recDNA's Avatar
    It's not for the battery. It's so the phone "learns" the extra capacity and gives you more accurate battery %. I would never drain the battery to 0. Never, never, never, never. It isn't good for the battery. I don't care if it costs me 10 minutes of runtime or whatever. I also wouldn't use anything but a stock battery for safety reasons.
    07-06-2017 10:21 PM
  9. Mike Dee's Avatar
    From what I've learned most batteries do require some kind of conditioning and the best practices vary with the type of battery and or application.
    In my case I don't think the phone learns much because I use three different types of battery capacities.
    I go by my experience and I've never had a problem with third party batteries and I use them for a lot of applications that require hi speed charging and draining.
    I don't know how much battery life you actually save by following all of the suggested rules but I know I've got phones and other devices with sealed batteries that are over two years old that still have great battery life. The only exception for me has been laptop batteries. Those always seem to die early. In any event, I try to charge my phone before it gets to low but that doesn't always happen. I just go with what works for me. If I kill the V20 batteries I'll just buy new ones.
    07-07-2017 05:23 AM
  10. recDNA's Avatar
    I agree. If you swap batteries and I do too btw the phone cannot adjust perfectly to those batteries. I just swap genuine LG batteries so they are pretty much the same. Now if you get a Zerolemon battery the capacity is 3 times greater. If you want to have full access to it it is best to follow their directions. My experience with them is good. I also used another high capacity brand with good ratings. I'm sure I never got the last drop of energy out of either of them because I didn't like the added weight and always swapped back to OEM battery. I would not use "Bob's Zippypower" from China. I'd be afraid it would blow up. In other words there are other well known batteries besides LG. If they have great reviews on Amazon I'd try them. I would not try some unknown brand on Ebay.
    07-07-2017 07:49 AM
  11. recDNA's Avatar
    I got mine on ebay. Not as safe as Amazon but I think they ship everywhere. Original OEM external charger and battery.
    BTW, just because label says 4100maH doesn't mean it really is. I bet it is closer to 3000 than 4100 unless it is very thick and they gave you a new back cover to use on your phone.
    07-07-2017 07:54 AM
  12. Mike Dee's Avatar
    Yes....I stick with Amazon
    07-07-2017 08:42 AM
  13. christianttt's Avatar
    Yeah i'm sure 4100maH is not the real capacity. So far I've seen good feedback on this battery, but of course I would feel safer using a LG branded one. I'll take a look in Ebay.
    About calibration, I guess I don't have to worry about it if i'm changing batteries and getting enough battery life haha.
    07-07-2017 12:01 PM
  14. Mike Dee's Avatar
    If it was a small difference in the same size it would be possible, but 4100...that's a big stretch
    07-07-2017 04:07 PM
  15. Ejjba's Avatar
    I use the set from Amazon. International battery with charger. Switch them every few weeks. Works great
    07-10-2017 07:03 AM
  16. Mike Dee's Avatar
    07-10-2017 10:29 AM
  17. christianttt's Avatar
    Just an update. The battery and the charger work fine. Battery life is equal or superior than the original.
    When is at 0 can not be charged from the phone.
    07-30-2017 02:39 PM
  18. Mike Dee's Avatar
    so the phone recognizes it as the incorrect battery?
    I have extended capacity aftermarket and they don't have that issue.
    07-30-2017 02:51 PM
  19. christianttt's Avatar
    Only if you try to charge it from 0
    07-30-2017 09:58 PM
  20. Mike Dee's Avatar
    Interesting
    07-31-2017 07:13 AM
  21. christianttt's Avatar
    I just bought an original battery pack in ebay, 20 dollars with a 10 dollars discount.
    09-13-2017 11:17 AM
  22. natehoy's Avatar
    I would suspect in order to get the "same battery life as original" they are probably overvolting a little bit and using an inferior cell, which means the battery discharges much closer to "the battery is actually, truly dead 0%" than the stock battery does.
    If the voltage gets too low, there is some small risk in charging it. That initial "recovery" charge can generate a lot of heat in a hurry.
    So I strongly suspect when your battery is at 0%, your phone is saying "No, I'm not throwing power at that, lest it go all Thermite on me - that there is a dead-as-a-doorknob battery".
    The external charger is obviously not as fussy.
    If that is correct - and this is not unusual for an eBay cheapo battery, I would strongly recommend you never, ever run that battery down to "indicated 0%" again. Or if you do, always charge it with the charger they included, and avoid leaving it unattended or near flammable objects.
    The battery will *probably* work just fine as long as you don't fully discharge it ever again, and watch it carefully as it nears 100% (the BMS might be under-reporting that so it overcharges for a little extra battery life, and again - heat - thermite - bad things are unlikely but possible).
    Or, for 11 bucks, it might be advisable to look at the cost of a replacement phone if it fails in a bad way as compared to the price difference of a battery made by a more reputable manufacturer that stands a much lower chance of failing. Your phone, your battery, your decision to make. I'm advising, not judging.
    09-13-2017 03:35 PM
  23. recDNA's Avatar
    I got a battery on Ebay that works fine.
    09-21-2017 04:45 PM
  1. Application for battery saving when holstered.
    By undefinederror in forum Android Apps
    Last Post: 07-09-2017, 12:12 AM
  2. Note 5 Battery draining 50% overnight
    Last Post: 07-05-2017, 11:10 AM
  3. Samsung Galaxy Note3 Battery life problems.
    Last Post: 07-05-2017, 09:48 AM
  4. i think my battery is exchanged with mwit
    Last Post: 07-05-2017, 03:08 AM
  5. So bad back up of battery life
    Last Post: 07-04-2017, 11:15 PM
