The SD card will make no discernible difference in battery life. You have something else going on. Have you looked at the battery stats to see what is using the battery?
Probably a bad microSD. If you just bought the phone brand new, give it 1-2 weeks for the battery and OS to optimize. You'll see improvement afterwards.
