Lg V20 Bluetooth problems
Kyle Workman
I have an LG V20 and it has a problem when connecting to my car stereo. It shows it's connected and playing on the phone and on the stereo but it had no sound coming through. It works as soon as I disconnect and reconnect however. Didn't have this problem with my S5 sport. i think it's the stereo not the phone but I just think it's weird.
Mooncatt
Ambassador
Feb 23, 2011
10,751
311
83
I've had similar problems with mine, but I just got the stereo in my work truck (Good ol' aux cable in my car) and not sure where the problem lies. It seems to be most prevalent if I have the key in accessory to listen with the motor off, then immediately start it up. That temporary power cut and reboot of the radio seems to screw with the connecting handshakes.
calicocat2010
890
I've been having BT problems too especially when syncing my miniHD speaker to my phone. I'm able to get maybe 7 minutes of streaming then suddenly the BT turns off while I'm the shower. It's so annoying. I did a test this morning and synced the speaker to my Note 5. It it played seamlessly throughout my entire shower. Everytime I go and mess with the BT settings, I get some alert saying android.app.settings or w/E has stopped responding. Not very happy with my LGV20 right now.
Chris Dontworryaboutit
82
I have the same issue with my Subaru. half the time it plays but no sounds. turning the stereo on d off brings the sound back. Other times it will play but crash if I try to change the channel. Always using Pandora by the way.
TNCattleDog
458
Best thing to do is unpair with your car or speaker, delete the pair and restart your phone and device then try to re-pair and connect. Usually fixes BT issues for me.
David
Mike Dee
Ambassador
May 14, 2014
23,368
192
63
Is that the only device you are having problems with.
calicocat2010
890
So you have not tired it with any other blue tooth device?
Well, the Bluetooth works fine for my Jabra Wave Headset for the ear, My Q Wander Fossil Watch, and my Samsung Level U Pro ANC wireless headset. Tapping the 'My Rogue' label doesn't always work and so sometimes I have to disconnect my Bluetooth entirely and then reconnect in order for my device to connect to my SUV.
recDNA
8,692
112
63
Mine doesn't disconnect but sometimes downloaded podcasts will just stop for no reason. Might need to hit play on 5 or 6x to hear it all
ogio
255
anybody figure this out?
i'm having the same issues connecting to my bmw x5. sound cuts out. phone still playing. have to close apps or disconnect and reconnect to get sound back on.
Mike Dee
Ambassador
May 14, 2014
23,368
192
63
Bluetooth problems are tough. Sometimes it's the car, sometimes it's the phone. You can try it in different cars to see if it's just an incompatibility with a specific car. Did it ever work in your car or something that stopped?
ogio
255
i've used the v20 with one other bluetooth speaker and i dont think i had issues. but on my bmw, i've had issues with 2 different v20s. maybe my bmw just dont like v20s. never had problems with samsungs.
i can try asking bmw dealer if they know anything.
Laila Nance
