Mike Dee
Ambassador
In airplane mode with wifi disconnected?
No...you need streaming access.
I read in an earlier post Verizon had the FM antenna removed in their version of the V20 therefore you cannot enable it since the antenna does not exist.
Yes, both at the same time, it wouldn't let me do anything in the app.In airplane mode with wifi disconnected?
Your Welcome . It looks like it's only working on a data signal though on my device... I don't know if it is actually using the tuner in the device though.
Yeah, thanks. I was looking for the tuner or LGs FM Radio app, but no luck. No tuner in the Next radio as well.Also, when the radio is built it, it has a tuner like an FM radio.
Working in my S8 on T-Mobile also!
But we are talking about the V20, it works on other phones.
