1. datum9's Avatar
    That's my next device. V20 + extended ZeroLemon battery.
    they upped the capacity to 10,000 mAh. Or 3 times the size of the original, which is not adequate.
    10-24-2017 01:59 PM
  2. L0n3N1nja's Avatar
    I had the zero lemon for my Note 2, battery easily lasted 3 days, didn't use it daily because it was heavy enough to pull down on my pants in a way I didn't like.
    recDNA likes this.
    10-24-2017 02:35 PM
  3. datum9's Avatar
    the real benefit of an extended battery is the case is larger, making it easier to hold.
    Some phones are so slim and slippery, like you are holding an ice cube slightly larger than a credit card. In the original form, V20 is so slim and thin that it's hard to hold on to. ZL battery and its oversized case changes that.
    recDNA likes this.
    10-24-2017 02:37 PM
  4. recDNA's Avatar
    Just wish the case had a kickstand.
    10-28-2017 01:53 PM
  5. recDNA's Avatar
    Heck a 5000 maH battery with a symmetrical case and kickstand would do the trick for me.
    11-04-2017 02:56 PM
  1. What is the best memory card for LG V20?
    By Danielmdmj in forum LG V20
    Last Post: 11-11-2017, 04:24 PM
  2. Replies: 1
    Last Post: 10-24-2017, 11:13 PM
  3. How to preserve the longevity of the battery?
    By Allen Kong in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-24-2017, 09:54 PM
  4. Great experience with Samsung Service Centre
    By Ecm in forum Samsung Galaxy S8 & S8+
    Last Post: 10-24-2017, 12:04 PM
